Go to Post I'm very excited for this year, because robots. - pyrtle [more]
Unread 22-03-2009, 16:44
Johnny's Avatar
Johnny Johnny is offline
We do it for the pizza
FRC #1266 (The Devil Duckies)
Johnny has a spectacular aura aboutJohnny has a spectacular aura aboutJohnny has a spectacular aura about
Re: CIM Reduction?
AndyMark also sells a planetary gear box for the CIM. From my experience, it's much easier just to buy the one from AndyMark then it is to make the fittings for the CIM to the FP gearbox. it is, however, kind of expensive(120$).
Unread 22-03-2009, 16:52
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Re: CIM Reduction?
http://us.st12.yimg.com/us.st.yimg.c..._2042_15328105
This piece needs to have be reamed to 0.3105-0.3110. Then it will fit with the cim.
These are the directions take directly from the website
Modification for CIM Motor input
1. The bore of the Sun Gear of the AM Planetary needs to be reamed to 0.3105-0.3110 for a press fit onto the CIM motor shaft (we do not offer this part)
2. The end of the CIM Motor shaft, sticking out past the Sun Gear needs to be cut off
3. The cap plate on the AM Planetary needs to be flipped over so that the 3 counterbore holes for the #10-32 mounting screws are facing outward.
4. The cap plate needs to be mounted to the AM Planetary before the CIM Motor is mounted.
And
If I read this correctly, the OP has already bought the gearbox and wasn't satisfied with the fischer price, so he'd like to convert it for it to be usable with a cim. Otherwise your right, definately save yourself the time and buy the AM Cim Planetary.
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Weight Reduction Rob Colatutto Technical Discussion 38 20-01-2007 11:34
Quoted picture size reduction sanddrag CD Forum Support 1 25-07-2006 19:05
Weight Reduction Help. Mirza95vx Technical Discussion 11 07-02-2005 16:03
Gear reduction question dmellich Motors 6 25-01-2003 08:54
