Go to Post Honestly though, having a cave would be one of the greatest places to build a robot. There's already lack of light and lots of floor space! Well, if you have a good cave sponsor, that is. - Bryce Clegg [more]
Unread 22-03-2009, 16:50
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Re: CIM Reduction?
We actually just did this the other day, so here are some tips. First of all, I would suggest buying a few extra pinion gears, especially if you don't have a lathe, just in case one gets messed up. To get the press fit to work, your hole needs to be very precise. We used this precision reamer, and the diameter worked well:
McMaster part number: 3002A27
Also, in order to bolt the CIM motor onto the gearbox you need to use the slots in the side of the gearbox. However, these have very little clearance. We bought an L allen key (I think 5/32" but I could be wrong), and cut it down to about .5" to get it in the slots.
Also, once you've mounted everything, check the amperage running through the CIM motor mounted to the gearbox. It should be pulling around 3.5 amps, but if it's pulling more, you should check that you cut down the CIM shaft far enough and that the hole you reamed down on the pinion gear is centered.
Mens et Manus
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Weight Reduction Rob Colatutto Technical Discussion 38 20-01-2007 11:34
Quoted picture size reduction sanddrag CD Forum Support 1 25-07-2006 19:05
Weight Reduction Help. Mirza95vx Technical Discussion 11 07-02-2005 16:03
Gear reduction question dmellich Motors 6 25-01-2003 08:54
