Go to Post Leadership is demonstrated by initiative, examples, and spirit. Decisions are made by those who show up. The world is whatever you make of it. - Ken Leung [more]
Unread 22-03-2009, 21:08
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
Re: CIM Reduction?
Thank you everybody for the help. you were all very informative.
Planetary gears have a ring gear (outside), planet gears, and a sun gear (center). The sun gear must be reamed--that means that you need a reamer and at least a very straight drill press, if not a mill. A drill bit might work, but I'd go with a reamer.
What you're doing is expanding the hole slightly and smoothing it out. Press fit means that you have to push really hard on the gear to get it onto the shaft of the motor.
I have a mill and I am quite familiar with it. I've never used a reamer before, but if it is anything like a drill, then we should be good to go. thanks for the help.
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Weight Reduction Rob Colatutto Technical Discussion 38 20-01-2007 11:34
Quoted picture size reduction sanddrag CD Forum Support 1 25-07-2006 19:05
Weight Reduction Help. Mirza95vx Technical Discussion 11 07-02-2005 16:03
Gear reduction question dmellich Motors 6 25-01-2003 08:54
