Go to Post Sorry, during my fluid mechanics lectures on drag I must have been designing a gearbox in my mind. FRC season will do that. - sanddrag [more]
Unread 21-03-2009, 21:40
funstuff's Avatar
funstuff funstuff is offline
AKA: Kat
FRC #4096 (Ctrl-Z)
funstuff has a spectacular aura aboutfunstuff has a spectacular aura about
Send a message via AIM to funstuff
Re: More Wheels?
Originally Posted by lynca View Post
In 2002, 624 made a robot with a 5th high traction wheel in the middle of the robot for pushing/shoving during the game. I don't have a picture of the robot but it was a beast. If anyone has a picture I would love to see that robot again!
I'm not sure that the 5th wheel will help you since you would be dividing your normal force by 5 wheels instead of 4 wheels.
A 5th wheel helps with traction when you have carpet but not with FRP !
http://cryptoniterobotics.org/images/2002.jpg
^ the 2002 robot, minus side panels and bumpers. And it was the most beastly robot FRC has seen. It pulled a small car (or so I've heard). Last that I have heard, it is still in (somewhat) working order.
For Andy's reminiscing pleasure: http://cryptoniterobotics.org/team/robots/
-Kat
2011-present | FRC 4096 | Technical/Mechanical Mentor
2006-2007 | FRC 624 | Electrical Subteam Captain, Strategist
2005-2006 | FRC 624 | Build Captain, Driver
2004-2005 | FRC 624 | Mechanical Subteam Captain, Driver
2003-2004 | FRC 624 | Driver
Unread 21-03-2009, 23:16
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Re: More Wheels?
i meant to get a closer look at SPAM's robot (180) at Florida but I believe they have, in addition to their normal drive and a fan, a set of wheels possitioned perpendicular to the others and they would pneumatically lower the wheels. these were mainly for a semi-swerve affect, but i suppose could be used as a break. I'm sorry i dont have a better explaination i only saw it from the stands.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 22-03-2009, 00:58
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Re: More Wheels?
Is it possible (and legal) that you make pneumatics strong enough that you mount a wheel perpendicular to other wheels, then when you want to brake, you gently lift the robot using that wheel, tilting it just ever so slightly, and applying that downward pressure and braking faster?
Imagine sliding your hand over the desk, and the sliding your hand over the desk with a lot of downwards pushing..?
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 22-03-2009, 01:08
CraigHickman
Posts: n/a
Re: More Wheels?
You can only use up to 78 rover wheels in contact with the ground. No more.
Unread 22-03-2009, 01:46
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: More Wheels?
If you think about it, that will only work as long as the robot mass is accelerating upwards.
As soon as the robot stops accelerating upwards (and begins to coast), the force pushing down on the wheels will return to its pre-acceleration value. But a robot cannot possibly keep moving upward forever, or even offset a partial amount of its downward acceleration due to gravity.
Therefore, the robot must begin to slow down its upward velocity, experiencing negative acceleration. During this period, the robot will actually have less normal force pushing down on the wheels, meaning less pushing power.
So yes, you can do this; you'd just get a very limited period of increased traction followed by a limited period of decreased traction.
Think of if like a roller coaster. When you go through a dip, you feel positive gee forces, and when you go over a peak you feel negative forces.
Art Dutra IV
世上无难事,只怕有心人.
Unread 22-03-2009, 01:58
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: More Wheels?
Thatz a bit harsh craig we wanted to use like 79.
R.C.
MadTown Robotics Team 1323
Unread 22-03-2009, 03:51
artdutra04's Avatar
Re: More Wheels?
Doing some napkin calculations (read: no optimization), 112 is the hard limit for number of wheels you can have contacting the floor.
Art Dutra IV
世上无难事,只怕有心人.
Unread 22-03-2009, 08:18
David Doerr's Avatar
David Doerr David Doerr is offline
FRC #4478 (Materia Oscura)
David Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud of
Re: More Wheels?
Our Software & Controls group has done very precise calculations and found that, at least for our machine, the limit is 112.67 wheels.
Unread 22-03-2009, 10:19
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: More Wheels?
That's what you get for having your software guys do hardware calculations.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 22-03-2009, 10:26
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: More Wheels?
-Kat
Thanks for the trip down memory lane !
I'm glad to see 624 won the regional at Bayou !
Go CRyptonite !
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 22-03-2009, 11:19
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: More Wheels?
Wow ... Drill motors, No Kitbot Chassis, and the revolving light (How I loved that light).
___________________
- Tennyson, Ulysses
Unread 22-03-2009, 17:36
mjazzka's Avatar
mjazzka mjazzka is offline
THUNDERCAT
AKA: Michael Jaska
FRC #0624 (Cryptonite Robotics)
mjazzka is infamous around these parts
Re: More Wheels?
Here is a picture of our robot from that year for ya! We just call it the tank bot, and it just sits there doing nothing. And btw, that 5th wheel is the butt of many, many jokes lol. The 5th wheel is in the center of the robot, kind of hidden but nevertheless there.
http://picasaweb.google.com/RazorTip...3129 88959794
Unread 22-03-2009, 18:34
reversed_rocker's Avatar
reversed_rocker reversed_rocker is offline
Alumni
AKA: Ken Condon
FRC #0706 (Cyberhawks)
reversed_rocker is on a distinguished road
Re: More Wheels?
adding more wheels may increase your surface area, but it spreads out your weight. The net gain in traction: exactly 0. Even extra powered wheels dont help, assuming you keep the amount of power is the same. the only reason why 4 powered wheels could be better than two powered wheels is 1: more motors to power the 4 wheels, therefore more power or 2: if some of your wheels dont have traction, it's possible to pull yourself out of a bind with the wheels that do. It's a common misconception that more wheels = more traction, thats why you see so many 4 wheel drive cars in the ditch during wisconsin winters
Unread 22-03-2009, 22:26
funstuff's Avatar
AKA: Kat
FRC #4096 (Ctrl-Z)
Re: More Wheels?
Thanks, Michael. I only wish we had more than one picture of Tankbot from that year.
We have used it in demonstrations at least through 2007.
Unread 22-03-2009, 22:45
mjazzka's Avatar
THUNDERCAT
AKA: Michael Jaska
Re: More Wheels?
LOL i did NOT see you had already posted a picture, sorry about that
And I will work on getting more pictures of that robot for you, it is still lying around SOMEwhere...
Coach/Strategist, and Manipulation Captain for 2009 "Lunacy"
Ultimate Frisbee Enthusiast
Has Being In FIRST Made You More Brave - More Confident? JaneYoung General Forum 25 08-05-2007 10:11
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Image Discuss: Wheels- you want wheels - more from team 25 CD47-Bot Extra Discussion 10 07-09-2003 20:33
More Wheelchair Wheels archiver 2001 0 23-06-2002 23:15
More Wheelchair Wheels archiver 2001 1 23-06-2002 23:15
