Go to Post How do You Chiefdelphi? :cool: - SpaceOsc [more]
Unread 22-03-2009, 23:30
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: 1726 in practice
The camera tracking and making long shots looks great when it works, but we tried to get the camera adjusted in LA and the lighting was just a bit too challenging, so we went with manual control, at short range, with the downward pointing shooter. We didn't quite get the hang of it in LA and lost in the semis, but in Phoenix we started out with it shooting down and it worked great, we lost only one match. Mind you, there was a bit more competition in LA, with several "power dumpers" able to score big globs of balls in no time flat...none of the AZ teams had robots quite like 973/399/1388/207!
If you can use the camera reliably, that would be really nice to see
Unread 22-03-2009, 23:38
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Squirrel, your bot this year rocks and has a great color scheme to it. How many balls can you hold max. Also thanks for the tin snips.
R.C.
MadTown Robotics Team 1323
Unread 22-03-2009, 23:41
MrForbes's Avatar
AKA: Jim
Thanks! the kids did a great job. It seems to hold about 15 or 16 balls...and you're welcome!
It's amazing what you can do with some plywood, krylon paint, and plumbing supplies if you try
Unread 22-03-2009, 23:45
R.C.'s Avatar
Are their any bristtles or pneumatic tubing coming out of the center of the helix to help the balls up btw?
R.C.
Unread 22-03-2009, 23:53
MrForbes's Avatar
AKA: Jim
It has some of that grippy shelf liner on it, attached to form "flaps" about an inch wide.
Unread 22-03-2009, 23:54
R.C.'s Avatar
Very interesting, any idea where to get, we were thinking of adding an agitator to our hopper to help fix jams and making our hopper bigger.
R.C.
Unread 23-03-2009, 00:06
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
We got ours at the local WalMart for about four dollars per roll. Rather than compressing the balls to push them up the helix, the central roller slaps them really fast (1200 rpm), meaning there is very little load on the motor driving it.
Unread 23-03-2009, 00:20
MrForbes's Avatar
AKA: Jim
We had a jamming hopper in 2006, which is one reason why we have a helix this year...a single ball path helps to prevent jamming.
If your robot design allows it, see if you can make a narrow path that the balls follow. I didn't get any pictures of your robot after you added the metal sheeting on it, but the one with the netting makes it look like the ball path is not much wider than one ball, but it doesn't really have anything at the top to keep the balls all in one line, they can bunch up next to each other.
MrForbes's Avatar
AKA: Jim
Another picture, here we're replacing it, it lasts one regional
pic: 1726 - portable OI TheOtherGuy Extra Discussion 1 07-03-2008 18:53
pic: 1726 guts TheOtherGuy Extra Discussion 1 19-02-2008 01:15
pic: 1726 week 4 TheOtherGuy Extra Discussion 29 04-02-2008 00:36
pic: 1726 Promobot GUI Extra Discussion 18 01-11-2007 18:04
pic: 1726 2007 OI TheOtherGuy Extra Discussion 2 11-02-2007 23:17
