Re: pic: 1726 in practice
Squirrel, your bot this year rocks and has a great color scheme to it. How many balls can you hold max. Also thanks for the tin snips.
Thanks! the kids did a great job. It seems to hold about 15 or 16 balls...and you're welcome!
It's amazing what you can do with some plywood, krylon paint, and plumbing supplies if you try ![]() |
Are their any bristtles or pneumatic tubing coming out of the center of the helix to help the balls up btw?
It has some of that grippy shelf liner on it, attached to form "flaps" about an inch wide.
We got ours at the local WalMart for about four dollars per roll. Rather than compressing the balls to push them up the helix, the central roller slaps them really fast (1200 rpm), meaning there is very little load on the motor driving it.
#7
If your robot design allows it, see if you can make a narrow path that the balls follow. I didn't get any pictures of your robot after you added the metal sheeting on it, but the one with the netting makes it look like the ball path is not much wider than one ball, but it doesn't really have anything at the top to keep the balls all in one line, they can bunch up next to each other. |
#8
Another picture, here we're replacing it, it lasts one regional
| pic: 1726 - portable OI | TheOtherGuy | Extra Discussion | 1 | 07-03-2008 18:53 |
| pic: 1726 guts | TheOtherGuy | Extra Discussion | 1 | 19-02-2008 01:15 |
| pic: 1726 week 4 | TheOtherGuy | Extra Discussion | 29 | 04-02-2008 00:36 |
| pic: 1726 Promobot | GUI | Extra Discussion | 18 | 01-11-2007 18:04 |
| pic: 1726 2007 OI | TheOtherGuy | Extra Discussion | 2 | 11-02-2007 23:17 |
