Go to Post Yeah After we decided not to do autonomous, the robot took matters into it's own hand. i'd bet it would get it's self DQ'd... or an award. - GMKlenklen [more]
Unread 03-23-2009, 12:33 AM
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Re: HELP: Robot Crash in Autonomous
Originally Posted by byteit101 View Post
also if you do this
 type *varname;
varname=value;
you assign varname's address at memory the value of value
you need to do this
type *varname;
*varname=value;
OR
type *varname;
varname=&value;
Generally speaking, yes. However, OP's assignment of the only pointer he is using is correct:
struct Command *currentCommand;
currentCommand = command_list_X;
command_list_X is an array of "struct Command". Assigning to a pointer using an array (of the same base type) is perfectly legitimate and will simply result in the pointer pointing to the base of the array.
Very Strange cRIO Crash Hunter1100 C/C++ 0 01-19-2009 04:39 PM
HDD crash, need help recovering data! David Kelly IT / Communications 16 05-28-2007 11:25 PM
PlasmaCam Crash Course Andrew Blair Technical Discussion 0 12-30-2005 09:48 PM
Prom Night Crash Nate Edwards General Forum 5 05-28-2005 03:15 PM
3dsmax5 Crash? yangotang Inventor 5 03-09-2003 09:17 PM
