Go to Post On the contrary, you've had several helpful responses. You might be confusing "helpful" with "do my homework for me." - Rick TYler [more]
Unread 23-03-2009, 06:36
cbeavers6790's Avatar
cbeavers6790 cbeavers6790 is offline
AKA: carroll
FRC #3542 (Team S.P.E.E.D)
cbeavers6790 will become famous soon enough
Question driver visibility
My teams drivers are having trouble seeing our robot on the field. The robot is nearly at the hieght limit and the drivers still cant see it very well. Would we be allowed to build a stool or platform for them to stand on during the compitition? It doesnt say in the rule book or any updates. Thanks for all your help
Unread 23-03-2009, 07:50
Re: driver visibility
C,
I have not heard of anything that would prevent you from asking. Are your team members height challenged? If so, I think you could ask for some "apple boxes" to stand on. Be advised that if you are at a normal height, the driver's station is a limited height. There are the team number boxes, clock and team lights that would obstruct your line of sight if you go up too high.
*apple box is a term used in stage and TV production to add height to objects or people. Typically about 4" high.
Unread 23-03-2009, 11:58
Be advised, this may fall under "competitive advantage" for the drivers. Go ahead and make the boxes, but ask first so you don't get any unwelcome surprises.
Unread 23-03-2009, 12:00
BenX02's Avatar
BenX02 BenX02 is offline
FRC #2655 (The Flying Platypi)
Team Role: Driver
BenX02 has a spectacular aura aboutBenX02 has a spectacular aura about
Are your drivers really short? Because I am no where near tall, and I could see just fine unless the robot was behind other robots.
As for the legality of it, I don't see why not. But definitely ask first to avoid any unwanted penalties.
Unread 23-03-2009, 12:01
I the rule you are looking for is <T22>.
Unread 23-03-2009, 12:18
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
If you are having a hard time seeing your bot, add colors. Certain colors are off limits such as the pink or green of the trailer. However, I think a bright yellow shouldn't mess with the sensors and should be easy to see. You might want to check on this though. I've not worked with the sensors personally as I am not a programmer and do not really know if this would interfere or not.
Anyone else have a good color to grab one's attention and won't interfere with sensors?
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 23-03-2009, 12:22
Molten's Avatar
AKA: Jason
If they have a disability which causes them to be short, then this rule would not apply.
Unread 23-03-2009, 12:56
Aren_Hill's Avatar
Build Nifty Things
We tried to have a driver bring a stool out in 06 at IRI, and it was denied because it provided an advantage, even though she was like 5 ft tall.
A guy who likes robots.
Unread 23-03-2009, 13:00
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
it would provide a huge advantages as you can see the location of the balls better.
Unread 23-03-2009, 13:05
Aren_Hill's Avatar
Build Nifty Things
hence why we werent disputing it, we just gave it a shot to see if she could
Unread 23-03-2009, 13:16
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
What about elevator shoes? I can't see them denying that, any more than they would deny hearing aids to a hearing impaired person, or glasses to someone that is nearsighted.
Former Mentor Team 1771
Former mentor Team 4509
Unread 23-03-2009, 13:28
pitzoid's Avatar
pitzoid pitzoid is offline
AKA: BOB
no team (4FX Design)
pitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of light
If they are "height challenged" I could see a case being made with that rule....
BotBash BOB Pitzer
Harvest CROO Robotics and 4FX Design
Unread 23-03-2009, 13:35
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Gets you another few inches! Plus they're uh . . . . trendy!
Oh, just don't forget to feed the goldfish!
Last edited by Matt C : 23-03-2009 at 13:37. Reason: can't forget to feed the goldfish!
Unread 23-03-2009, 13:38
For your discussion...
<T22>
The only equipment that may be brought on to the field is the OPERATOR CONSOLE, reasonable decorative items, and special clothing and/or equipment required due to a disability. Other items, particularly those intended to provide a competitive advantage for the TEAM, are prohibited.
Unread 23-03-2009, 13:49
Killraine Killraine is offline
Team Robot
AKA: Josh Lucas
FRC #2016 (Mighty Monkey Wrenches)
Killraine will become famous soon enoughKillraine will become famous soon enough
We painted the top of our robot blue (team color) and our driver and operator both said it was really easy to identify the location of the robot.
Ball Visibility zachriggle Technical Discussion 3 20-02-2006 02:59
Serial Driver and 2K6 Encoder Driver Not compatible Tom Bottiglieri Programming 6 12-02-2006 01:11
Visibility for the Driver SouthBronx General Forum 32 08-02-2003 22:32
Visibility Pete Lloyd General Forum 3 05-01-2003 23:43
visibility Tyler Olds 3D Animation and Competition 0 12-03-2002 16:14
