Go to Post We'll see how this goes... it could be fun. - Andy Baker [more]
Unread 21-03-2009, 22:59
mgoodell6 mgoodell6 is offline
AKA: Mark Goodell
FTC #1902 (Exploding Bacon)
mgoodell6 is an unknown quantity at this point
Capturing Camera Images to cRIO
I have not been able to get the frcWriteImage() function to work. I am using code from the WindRiver camera example but receive a frcWriteImage failed each time I try to save an image. Any help with this would be appreciated.
Here is the code I am using
if ( !GetImage (cameraImage,NULL) ) {
printf ("\nCamera Acquisition failed");
} else {
if (!frcWriteImage(cameraImage, "image.jpeg") ) {
printf ("frcWriteImage failed");
} else {
printf ("\n>>>>> Saved image to %s", "image.jpeg") );
// always dispose of image objects when done
frcDispose(cameraImage);
Unread 22-03-2009, 16:36
Sentient's Avatar
Sentient Sentient is offline
FRC #0639 (Code Red)
Sentient is on a distinguished road
Re: Capturing Camera Images to cRIO
Is cameraImage a pointer?
Unread 22-03-2009, 19:55
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Not only do we have code that does this, but I took home the school laptop from the waterloo regional, so I have it on me. This is debug code that isn't critical, so forgive the lack of error checking and memory-freeing.
void SavePictures(TrackingThreshold& tGreen, TrackingThreshold& tPink)
  Image* cameraImage = frcCreateImage(IMAQ_IMAGE_HSL);
  GetImage(cameraImage, NULL);
  Image* thresImage = frcCreateImage(IMAQ_IMAGE_HSL);
  frcColorThreshold(thresImage,cameraImage,IMAQ_HSL,&tGreen.hue,&tGreen.saturation,&tGreen.luminance);
  frcWriteImage(thresImage,"green.jpg");
  frcColorThreshold(thresImage,cameraImage,IMAQ_HSL,&tPink.hue,&tPink.saturation, &tPink.luminance);
  frcWriteImage(thresImage,"pink.jpg");
  frcWriteImage(cameraImage,"raw.jpg");
This was copied by hand from our code on the laptop, so it probably has some typos. I think the only thing different is that you were not frcCreateImage-ing your image to allocate it.
If you do the thresholding stuff like we did, one note is that you should modify frcColorThreshold so that it sets the "on" color value to something other than 1 (the default in WPILib) so it is easy to see the colors in the thresholded images. We spent quite awhile debugging our thresholding, saying "why are we getting pure-black images" until we realized that they only appeared black, and actually contained data.
Unread 23-03-2009, 11:47
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
} else {
} else {
My first guess as to the problem is that you may need to supply a full path to the filename. (i.e. /image.jpeg )
Second guess is that you need to allocate storage for cameraImage prior to the above code. (e.g., you need to use "frcCreateImage(IMAQ_IMAGE_HSL)")
Third guess is that way back once upon a time, vxWorks FAT filesystems had problems with file extensions of longer than 3 characters, so switching to a .jpg extension might help.
In any case, as an example of working code, below is the code that we are using to capture snapshots. The below code is "cut and paste" directly out of our code, so it doesn't contain any typos.
void TwoColorTracker::Snapshot() {
	Image* cameraImage;
	char funcName[]="Snapshot";
	int retval;
	int errorCode = 0;
	// Put image in root directory. If another directory is used
	// it must exist on the cRIO.
	char* imageName = "/viewxxx.png";
	static int imageNum = 1;
	printf("test ");
	// Camera Snapshot code
	if (imageNum < 6 ) {
		printf("test2 ");
		sprintf(imageName,"/view%d.png",imageNum);
		imageNum++;
		//printf("taking a SNAPSHOT ");
		if (!cameraImage)  {
			errorCode = GetLastVisionError();
			DPRINTF(LOG_INFO, "Unable to create %s Error = %i %s", imageName, errorCode, GetVisionErrorText(errorCode));
			return;
		if ( !GetImage(cameraImage, NULL) ) {
			DPRINTF(LOG_INFO, "\nCamera Acquisition failed %i", GetLastVisionError() );
		} else {
			retval = frcWriteImage(cameraImage, imageName);
			if ( retval ) {
				printf ("frcWriteImage succeeded.");
			} else {
				//errorCode = GetLastVisionError();
				//DPRINTF(LOG_INFO, "frcWriteImage failed, Error = %i %s", imageName, errorCode, GetVisionErrorText(errorCode));
				printf ("frcWriteImage '%s' failed.", imageName);
		frcDispose(funcName, cameraImage, NULL);
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 26-03-2009, 07:24
AKA: Mark Goodell
Thanks
We implement this code and it is working like a charm.
Saving images/video from camera (LabVIEW) Chaos in a Can NI LabVIEW 3 16-08-2010 16:21
Connecting Axis camera to cRIO laultima FRC Control System 20 21-01-2009 16:56
Capturing images from a Flash file JohnBoucher IT / Communications 2 03-12-2007 15:14
Capturing Video from camera with Premiere 5.5 sanddrag IT / Communications 14 09-09-2005 04:45
