| Thread Tools |
Rating:
Display Modes |
driver's station DIO and joystick wheel
1) I would like to connect a switch to the DIO of the driver's station to enable our shooter. I've tried to look for an example in labview, but I didn't see any. Does anyone have example code as to how to do this? I looked at the WPI libraries and it isn't too intuitive as to how to use the driver station DIO vis.
2) I also would like to use the analog value returned by the joystick wheel. Has anyone done this? How do you get this value? Thanks! Last edited by windell747 : 24-03-2009 at 01:33. Reason: changed #1 to contain a question |
Re: driver's station DIO and joystick wheel
Do a little searching on the forums before you post --Ryan |
I did do some searching before posting because I thought I saw the answers to my questions before, but I couldn't find them again. I think i was looking in the wrong spots. I'm not the lazy type so I wouldn't post unless i did some searching first.
| Driver's station to be used at competition. | Joshamuffin | Control System | 1 | 16-02-2009 11:22 |
| Driver's Station | GillSt.Bernards | FRC Control System | 3 | 10-02-2009 23:12 |
| Driver's station - Consistency in construction | Duncan Macdonald | Technical Discussion | 3 | 10-12-2008 17:14 |
| Inside the driver's station | Jeff Rodriguez | Championship Event | 7 | 01-05-2008 22:04 |
| Need input on driver's station problem! | Hawkins | Control System | 9 | 03-04-2008 10:48 |
