Go to Post I blame FIRST for everything good that has happened to me. - Herodotus [more]
Unread 24-03-2009, 00:21
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
driver's station DIO and joystick wheel
1) I would like to connect a switch to the DIO of the driver's station to enable our shooter. I've tried to look for an example in labview, but I didn't see any. Does anyone have example code as to how to do this? I looked at the WPI libraries and it isn't too intuitive as to how to use the driver station DIO vis.
2) I also would like to use the analog value returned by the joystick wheel. Has anyone done this? How do you get this value?
Thanks!
Last edited by windell747 : 24-03-2009 at 01:33. Reason: changed #1 to contain a question
Unread 24-03-2009, 01:53
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: driver's station DIO and joystick wheel
See this thread
Read it like a joystick axis (like X or Y), but read Axis 3., as stated here
Do a little searching on the forums before you post
--Ryan
FRC 766, 2015-, Mentor
Unread 24-03-2009, 03:08
FRC #2477
I did do some searching before posting because I thought I saw the answers to my questions before, but I couldn't find them again. I think i was looking in the wrong spots. I'm not the lazy type so I wouldn't post unless i did some searching first.
Driver's station to be used at competition. Joshamuffin Control System 1 16-02-2009 11:22
Driver's Station GillSt.Bernards FRC Control System 3 10-02-2009 23:12
Driver's station - Consistency in construction Duncan Macdonald Technical Discussion 3 10-12-2008 17:14
Inside the driver's station Jeff Rodriguez Championship Event 7 01-05-2008 22:04
Need input on driver's station problem! Hawkins Control System 9 03-04-2008 10:48
