Go to Post At FIRST, our only colors are red or blue. And we are only those for two minutes! - tenfour [more]
Unread 23-03-2009, 17:01
Re: Gyro problem
1 degree every 5 seconds doesn't sound too bad (IE, inline with what I've seen with the new control system). You can play with AnalogChannel::SetAccumulatorDeadband if you want to (I think it is a relatively new addition). There was a big thread a few years ago debating whether it was better to have the dead band or not, as having the deadband may throw off the results once you start moving.
You may want to confirm the legality of the ADXRS300 gyro, as Analog devices has stopped making it, and it looks like most suppliers have stopped carrying it.
Unread 23-03-2009, 17:08
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Re: Gyro problem
We observed significant standing-still error with the new control system as well, somewhere around this order of magnitude.
By modifying the Deadband, as suggested, we got much more stable results and still observed good accuracy when moving.
Unread 23-03-2009, 17:16
gwytheyrn gwytheyrn is offline
AKA: David
FRC #0461 (West Side Boiler Invasion)
gwytheyrn is infamous around these parts
Send a message via AIM to gwytheyrn
Re: Gyro problem
Also, check which analog channel you're using/try changing the channel. I'm not sure if this is true for everyone, but our module didn't like using the last analog in when we had the jumper for battery voltage on (Well...I guess we never tested whether it worked without it, since changing the channel worked).
Since it hasn't been mentioned, could the OP post about how fast the gyro measurement is drifting?
Unread 23-03-2009, 20:03
heydowns's Avatar
AKA: Jeff Downs
Re: Gyro problem
The battery voltage jumper controls what is fed to the last ADC channel on the analog module. You either get to measure battery voltage on that last channel, or you get to hook something up to the last channel header on the bumper and measure that.
So, your experience would hold for everyone on the first cRIO slot since the battery voltage measurement is required by the rules this year.
Unread 23-03-2009, 21:04
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Re: Gyro problem
After using the Reset VI for the gyro in Labview we noticed that the angle toggled between 359 360 and 0. Does anyone else have this issue? We've never seen this before with the previous controller and kevin's code.
I know 359, 360, and 0 are about the same but why would it not be -1 or -2 deg rather than 359 360.
Unread 23-03-2009, 21:09
AKA: David
Re: Gyro problem
Can you set the gyro up as an analog input (it's under i/o in the WPI stuff) and probe what it thinks is the voltage when still and when rotating?
Unread 24-03-2009, 02:13
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: Gyro problem
Thanks to all who have responded.
First of all, our gyro is wired and connected correctly, as we verified today. We had full confidence in the test gyro as we used it last year.
Second, the thing worked better today with a lot less drift - we did take care to leave the gyro alone for an extended period following initial power up. Other than that, no changes we can think of.
I would still like to know how to adjust the deadband. I did see the AnalogChannel::SetAccumulatorDeadband reference in mucking through the source code. What would the syntax be to call this for the gyro channel on analog module 1, input 1?
Finally, it looks like the ADXRS610 is the replacement for the ADXRS300. I'll have to look into that one.
Unread 24-03-2009, 07:22
yoyodyne yoyodyne is offline
AKA: Greg Smith
FRC #0116 (Epsilon Delta)
yoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to behold
Re: Gyro problem
We combined gyro and one channel of accelerometer processing so that we could use the same calibration interval for both (and changed the calibration period to 2 seconds which seems to be plenty). Also, we wanted functions to return the filtered angular rate for the gyro and the acceleration and speed from the accelerometer. Anyway, we also used a known good 300 degrees/sec gyro as well as this year's KOP gyro. To do this we copied the WPILib code into our project and then modified it. Part of our modified code is below - notice that we set the deadband for both to 10.
Hope this helps.
The code that set's up the gyro and accelerometer is here:
#ifdef PRACTICE_BOT
#define GYRO_SENSETIVITY 0.0055 /* LAST YEAR's GYRO */
#else
#define GYRO_SENSETIVITY 0.006966667 /* 2009 Gyro */
#endif
void InitializeUtilities()
m_gyro = new GYRO_ACC(1,1,1,2);
m_pressure_switch = new DigitalInput(6,14);
m_autonomous_alliance = new DigitalInput(4,6);
m_initial_position1 = new DigitalInput(4,7);
m_initial_position2 = new DigitalInput(4,8);
m_play_1s = new AnalogChannel(2,3);
m_play_10s = new AnalogChannel(2,4);
// m_compressor_relay = new Relay(4, 1, Relay::kForwardOnly);
m_gyro->SetSensitivity(GYRO_SENSETIVITY);
m_gyro->SetAccSensitivity(0.009666207);
m_gyro->Reset();
m_right_odo = new Encoder(6,3,6,4,false,CounterBase::k1X);
m_left_odo = new Encoder(6,1,6,2,false,CounterBase::k1X);
m_right_drive = new Encoder(6,7,6,8,false);
m_left_drive = new Encoder(6,5,6,6,false);
* Initialize the GYRO_ACC.
* Calibrate the GYRO_ACC by running for a number of samples and computing the center value for this
* part. Then use the center value as the Accumulator center value for subsequent measurements.
* It's important to make sure that the robot is not moving while the centering calculations are
* in progress, this is typically done when the robot is first turned on while it's sitting at
* rest before the competition starts.
void GYRO_ACC::InitGYRO_ACC()
if (!m_analog->IsAccumulatorChannel())
wpi_fatal(GyroNotAccumulatorChannel);
if (m_channelAllocated)
delete m_analog;
m_analog = NULL;
return;
if (!m_ana_accel->IsAccumulatorChannel())
if (m_accel_channelAllocated)
delete m_ana_accel;
m_ana_accel = NULL;
return;
m_voltsPerDegreePerSecond = kDefaultVoltsPerDegreePerSecond;
m_analog->SetAverageBits(kAverageBits);
m_analog->SetOversampleBits(kOversampleBits);
m_voltsPerG = kDefaultVoltsPerG;
m_ana_accel->SetAverageBits(kAverageBits);
m_ana_accel->SetOversampleBits(kOversampleBits);
float sampleRate = kSamplesPerSecond *
(1 << (kAverageBits + kOversampleBits));
m_analog->GetModule()->SetSampleRate(sampleRate);
Wait(0.25);
m_analog->InitAccumulator();
m_ana_accel->InitAccumulator();
Wait(kCalibrationSampleTime);
INT64 value;
UINT32 count;
m_analog->GetAccumulatorOutput(&value, &count);
UINT32 center = (UINT32)((float)value / (float)count + .5);
gyro_center = (float)value/(float)count;
m_offset = ((float)value / (float)count) - (float)center;
m_analog->SetAccumulatorCenter(center);
m_analog->SetAccumulatorDeadband(10); ///< TODO: compute / parameterize this
m_analog->ResetAccumulator();
m_ana_accel->GetAccumulatorOutput(&value, &count);
accel_center = (float)value/(float)count;
m_acc_offset = ((float)value / (float)count) - (float)center;
m_ana_accel->SetAccumulatorCenter(center);
m_ana_accel->SetAccumulatorDeadband(10); ///< TODO: compute / parameterize this
m_ana_accel->ResetAccumulator();
* GYRO_ACC constructor given a slot and a channel.
* @param slot The cRIO slot for the analog module the GYRO_ACC is connected to.
* @param channel The analog channel the GYRO_ACC is connected to.
GYRO_ACC::GYRO_ACC(UINT32 slot, UINT32 channel, UINT32 accel_slot, UINT32 accel_channel)
m_analog = new AnalogChannel(slot, channel);
m_channelAllocated = true;
m_ana_accel = new AnalogChannel(accel_slot, accel_channel);
m_accel_channelAllocated = true;
InitGYRO_ACC();
* GYRO_ACC constructor with only a channel.
* Use the default analog module slot.
GYRO_ACC::GYRO_ACC(UINT32 channel, UINT32 accel_channel)
m_analog = new AnalogChannel(channel);
m_ana_accel = new AnalogChannel(accel_channel);
InitGYRO_ACC();
Unread 24-03-2009, 07:49
AKA: Greg Smith
Re: Gyro problem
In that last post, I didn't address the gyro drift performance...
With a deadband of 10 it is pretty good. For example the beginning of our navigation dump file shows that the gyro drifted from 45.0 degrees to 44.999695 degrees in the period from when the robot was turned on RobotInit() until the field enabled autonomous which is maybe a minute or two?
In the dump section below, the robot was commanded to execute a CCW arc turn of 20 degrees/second with a forward speed of 0.5 until the heading was 0 degrees. x and y are the estimated field coordinates using the left and right odometry wheels and the gyro. h is the gyro heading, oh is the estimated gyro heading from using the odometry wheels alone, ox and oy are the estimated field coordinates using the left and right odometry wheels only (not the gyro). ror and rol are the raw encoder counts for the right and left odometry wheels.
arc: rate: -20.000000
arc: speed: 0.500000
arc: angle: 0.000000
arc: timeout: 10.000000
Nav: x: 4.000000, y: 4.000000, h: 44.999695, ox: 4.000000, oy: 4.000000, oh: 45.000000, ror: 5, rol: 5, Arc:
Nav: x: 4.000000, y: 4.000000, h: 45.002197, ox: 4.000000, oy: 4.000000, oh: 45.000000, ror: 5, rol: 5, Arc:
Nav: x: 4.000000, y: 4.000000, h: 45.002167, ox: 4.000000, oy: 4.000000, oh: 45.000000, ror: 5, rol: 5, Arc:
Nav: x: 4.000000, y: 4.000000, h: 44.997162, ox: 4.000000, oy: 4.000000, oh: 45.000000, ror: 5, rol: 5, Arc:
Nav: x: 4.000000, y: 4.000000, h: 44.988068, ox: 4.000000, oy: 4.000000, oh: 45.000000, ror: 5, rol: 5, Arc:
Nav: x: 4.000000, y: 4.000000, h: 44.989807, ox: 4.000000, oy: 4.000000, oh: 45.000000, ror: 5, rol: 5, Arc:
Nav: x: 4.000000, y: 4.000000, h: 44.992462, ox: 4.000000, oy: 4.000000, oh: 45.000000, ror: 5, rol: 5, Arc:
Nav: x: 4.000000, y: 4.000000, h: 44.990997, ox: 4.000000, oy: 4.000000, oh: 45.000000, ror: 5, rol: 5, Arc:
Nav: x: 4.000000, y: 4.000000, h: 44.989685, ox: 4.000000, oy: 4.000000, oh: 45.000000, ror: 5, rol: 5, Arc:
Nav: x: 4.000000, y: 4.000000, h: 44.994049, ox: 4.000000, oy: 4.000000, oh: 45.000000, ror: 5, rol: 5, Arc:
Nav: x: 4.000000, y: 4.000000, h: 45.000427, ox: 4.000000, oy: 4.000000, oh: 45.000000, ror: 5, rol: 5, Arc:
Nav: x: 4.000000, y: 4.000000, h: 45.004486, ox: 4.000000, oy: 4.000000, oh: 45.000000, ror: 5, rol: 5, Arc:
Nav: x: 4.000000, y: 4.000000, h: 45.007355, ox: 4.000000, oy: 4.000000, oh: 45.000000, ror: 5, rol: 5, Arc:
Nav: x: 4.000000, y: 4.000000, h: 45.008381, ox: 4.000000, oy: 4.000000, oh: 45.000000, ror: 5, rol: 5, Arc:
Nav: x: 4.000000, y: 4.000000, h: 45.008022, ox: 4.000000, oy: 4.000000, oh: 45.000000, ror: 5, rol: 5, Arc:
Nav: x: 4.002983, y: 4.002983, h: 45.004089, ox: 4.002979, oy: 4.002987, oh: 44.925629, ror: 7, rol: 6, Arc:
Nav: x: 4.003977, y: 4.003977, h: 44.996216, ox: 4.003973, oy: 4.003981, oh: 45.000000, ror: 7, rol: 7, Arc:
Nav: x: 4.005965, y: 4.005966, h: 44.985992, ox: 4.005961, oy: 4.005970, oh: 45.000000, ror: 8, rol: 8, Arc:
Nav: x: 4.008946, y: 4.008950, h: 44.970764, ox: 4.008940, oy: 4.008956, oh: 44.925629, ror: 10, rol: 9, Arc:
Nav: x: 4.011928, y: 4.011935, h: 44.966827, ox: 4.011915, oy: 4.011947, oh: 44.851257, ror: 12, rol: 10, Arc:
Nav: x: 4.013915, y: 4.013925, h: 44.959839, ox: 4.013899, oy: 4.013941, oh: 44.851257, ror: 13, rol: 11, Arc:
Nav: x: 4.016895, y: 4.016910, h: 44.955292, ox: 4.016878, oy: 4.016928, oh: 44.925629, ror: 14, rol: 13, Arc:
Nav: x: 4.020870, y: 4.020890, h: 44.957764, ox: 4.020850, oy: 4.020910, oh: 44.925629, ror: 17, rol: 15, Arc:
Nav: x: 4.022856, y: 4.022881, h: 44.940948, ox: 4.022836, oy: 4.022902, oh: 44.925629, ror: 18, rol: 16, Arc:
Unread 24-03-2009, 08:18
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Re: Gyro problem
Just a note on the ADXRS610 -- if using the EVAL-ADXRS610 board, this board is not pin-equivalent to the ADXRS300EB. There is an additional +5V input that needs to be wired on the EVAL-ADXRS610 (as compared to the ADXRS300EB) and we also found that the two EVAL-ADXRS610 boards we purchased from DigiKey did not have connected ground planes, contrary to the datasheet for the board. Accordingly, we also needed to explicitly connect both ground planes when wiring up the board.
I've been intending to email Analog Devices to let them know of the datasheet inaccuracy, but I've been waiting until I get a round tuit.
Just figured I'd try to save you the 6 or so hours we wasted figuring out the above.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 24-03-2009, 09:30
Re: Gyro problem
We found the same thing, but it took us longer then 6 hours
Unread 24-03-2009, 16:17
Re: Gyro problem
I have not seen that in LabVIEW. Are you sure it's not something in your code?
Unread 24-03-2009, 17:19
O-H
Re: Gyro problem
Thanks once again for all the code samples and other time-saving advice in this thread. I think my team will find the information very useful in the near future.
Unread 24-03-2009, 23:29
Re: Gyro problem
OK, Given the fact that at least two of us ran into this, I sent an email off to Analog Devices -- I'll let you all know what I find out...
Unread 26-08-2009, 14:41
emersont49 emersont49 is offline
#1098
emersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of light
Re: Gyro problem
I'm using the KOP gyro with Labview. I connected it to Analog 1 and used the code in the Gyro example.
When I reset the gyro, it doesn't return to 0. The value seems to be consistent (about 0.05 or so). Is this something I can deal with using the temperature input? The VIs don't appear to have any input for temperature.
What is a good a pproach for determining the Gyro offset value?
Tim Emerson
Gyro problem..HELP! zivo123 Programming 13 14-04-2008 12:06
gyro problem Guarana Programming 9 03-03-2008 15:48
Problem with gyro... capenga Programming 21 16-02-2006 19:25
Gyro code problem AMIRAM Programming 10 23-01-2006 04:26
