Go to Post But as with all things: we shall see. - pfreivald [more]
  #76   Spotlight this post!
Unread 24-03-2009, 09:04
Re: possible solution to the static problem
Several things to respond to here.
Drag chains were added and in place in Milwaukee but so was the ample use of staticide spray at all exposed carpet boundaries on the field. As were all regionals that week and beyond. No static issues were reported to me at Boilermaker.
A CRIO showing loss of packets and then a 20 second loss of control is more indicative of a loss of power to the Crio and subsequent reboot than a static issue. As Bob has pointed out, the static issue has been related to the DS which lacks any static protection particularly on the ethernet ports. A power loss during a hard hit with the field or another robot is not uncommon as well as disconnected 37 pin connectors. Although the main breaker is robust, it may not remain connected during a severe shock depending on it's orientation and mounting. The contacts have a relatively low mass but a multi G shock may inject noise or momentary open circuit under this condition.
Solution to camera problem techkid7 Programming 1 12-01-2009 08:42
Onan Generator Control Problem - RC as solution? RyanN Electrical 8 01-12-2008 16:45
pic: Banebots carrier plates problem & solution Elgin Clock Extra Discussion 14 10-03-2007 07:50
