Go to Post No, I'm not a Superhero...I'm a FIRST Mentor. Common Mistake. - Mr. Van [more]
Unread 03-18-2009, 07:12 PM
cactuarman's Avatar
cactuarman cactuarman is offline
FRC #0996
cactuarman is just really nicecactuarman is just really nicecactuarman is just really nicecactuarman is just really nicecactuarman is just really nice
Help connecting wireless bridge
I was trying to get the wireless bridge to work. I looked at the manual(chapter 5) and followed each step. I got the wireless router and such all set up but on just about the last step(pg. 15 step 11) where it ask you to test your connection, I typed in 10.9.96.1 and nothing came up. I then connected it back to the wireless router with the cable and I typed in 10.9.96.1 and it worked. I double checked all the settings (IP address and such) and they seem to be okay. It seems as though I cant get it to connect wirelessly although wired works fine. Any help would be greatly appreciated.
Thanks.
Unread 03-18-2009, 07:23 PM
Re: Help connecting wireless bridge
Do the SSIDs for the wireless router and the WGA match perfectly? They should be your team number with no leading zeros.
Unread 03-18-2009, 07:33 PM
cactuarman's Avatar
FRC #0996
Yes, they match.
Unread 03-23-2009, 09:33 PM
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
turn off all security (both the WGA and router, we forgot this at the begining of the season, and spend about 2 meeting trying to connect, and after a regional doing the same)
Watchdog.Kill();
Unread 03-24-2009, 02:24 PM
gwytheyrn gwytheyrn is offline
AKA: David
FRC #0461 (West Side Boiler Invasion)
gwytheyrn is infamous around these parts
Send a message via AIM to gwytheyrn
Another possibility:
When you log on to your bridge, it will show you all available networks. Make sure your router is on there.
Otherwise, from what I read, the IP and stuff is set up right (check subnet mask?), but the wireless link isn't quite working. Perhaps check if they're both set up for the same band (5.4)?
Wireless bridge not allowing IP change Lord Byron FRC Control System 6 01-15-2009 05:55 PM
Source for Wireless Bridge Gary Bonner FRC Control System 1 01-07-2009 08:57 PM
Connecting the game bridge. Brion Technical Discussion 1 01-05-2009 11:12 AM
Wireless Bridge to Nowhere(Help Please!) TeknicllyInsane General Forum 3 12-11-2008 10:40 PM
Wireless Networks: Connecting buildings together KTorak IT / Communications 1 03-29-2005 08:41 PM
