Re: problems with velocity readout from encoderget vi
If you still can't get it, you can use the counter. The period output works for speed. One rev (Count of the counter) is one rev. of the encoder. Multiply that by the circumference of the wheel or whatever and you got the speed. You also get rev. here. You can multiply that by the circumference to get distance too.. that would save space. You must have a Digsrc if the encoder is analog!! You get some example code for it.
| Problems undeploying a program from the cRIO | ellisk | Programming | 2 | 29-12-2008 16:21 |
| Gyro problems, crossposted from Electrical | EFastring | Programming | 4 | 05-02-2008 10:16 |
| Problems Using PID for Velocity | Astronouth7303 | Programming | 6 | 10-02-2006 09:00 |
| Digital Caliper as a Digital Readout on Small Mill | sanddrag | Technical Discussion | 9 | 13-10-2005 22:51 |
| Translating pressure sensor readout into actual pressure | Mercutio | Pneumatics | 0 | 13-02-2004 16:29 |
