Go to Post Finding those students and giving them a lift up out of the sea of apathy that is constantly trying to drown them is one of the reasons I am in my profession. - Ben Mitchell [more]
Unread 23-03-2009, 21:55
gbzalla gbzalla is offline
FRC #2551
gbzalla is an unknown quantity at this point
Sprocket Ratios
Our team is currently involved in some last minute programming and we were having trouble figuring out what sprocket ratios to do our calculations with because obviously we shipped the necessary sprockets over a month ago with our robot. Here's our three questions:
1) Is the encoder axle the same as the drive axle (in terms of the gearbox for the 2009 KOP)?
2) How many teeth are on the drive sprocket (2009 KOP)?
3) How many teeth are on the driven sprocket (2009 KOP)?
Any help on this would be great! If any clarification is needed on any part of these questions I'd be happy to do so.
Thanks!
Unread 23-03-2009, 22:17
Ivan Helmrich's Avatar
Ivan Helmrich Ivan Helmrich is offline
FRC #1775 (Tigerbytes)
Ivan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to behold
Re: Sprocket Ratios
The KoP checklist,
http://www.usfirst.org/uploadedFiles...%20Rev%20B.pdf
has the drive sprockets at 15 teeth and the driven sprockets at 22 teeth. I believe the Toughbox has the encoder mounted on the output shaft.
http://lib.store.yahoo.net/lib/yhst-...ughbox-asm.pdf
Ivan
“The knowledge of what is relevant, what is not and the skill to cleverly work around or approximate solutions is the essence of engineering.” - James C. King
Unread 23-03-2009, 22:32
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Sprocket Ratios
That all sounds correct to me.
Unread 25-03-2009, 21:45
FRC #2551
Re: Sprocket Ratios
Thanks! This was a lot of help for our autonomous.
suggested gear ratios Bruceb General Forum 3 07-01-2009 14:15
Gear Ratios Joe_Widen Technical Discussion 17 13-05-2006 15:06
gear ratios roboteer49 Motors 22 29-04-2004 20:51
Gear Ratios Joshua May Kit & Additional Hardware 4 01-02-2004 22:54
Gearing Ratios satyam Motors 1 31-01-2004 09:50
