Go to Post There will be violence next year! YAY! - Koko Ed [more]
  #31   Spotlight this post!
Unread 25-03-2009, 23:06
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Virtual Driver Station
Good Call Tom, I think toggle would be better then having to use FMSLight.
  #32   Spotlight this post!
Unread 26-03-2009, 10:21
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Originally Posted by Tom Bottiglieri View Post
Would it be possible for this to talk to FMS Light? We are doing some tricky things with some hard timed loop, and I want to make sure our code will run in a competition environment. I am 99% sure it will be fine, but Murphy can always find that 1%.
If not, would it be possible to add controls to the GUI select alliance color? We pull that data from the DS object in WPILib. Right now the vDS returns kRed.
Yes, interoperability with FMS is something I had planned. I had actually decoded the FMS protocol first to produce an FMS-like program that would link up with any DSes it found rather than having to type in team numbers, so adding support should be straightforward.
In the meantime, however, I'll look into adding a toggle to select alliance color and position (though I'm guessing position isn't that useful to anyone since it has no bearing on where your robot is on the field).
  #33   Spotlight this post!
Unread 26-03-2009, 10:50
Thank you. This tool is quickly becoming more valuable to me than the real hardware. I know I'll still be using it once our new DS comes in.
  #34   Spotlight this post!
Unread 26-03-2009, 11:28
Software Engineer
Rookie Year: 1995
OK, I posted a new version that lets you use Ctrl-C to toggle the alliance color. It's not the best implementation but it was something that I could do quickly to try to meet your needs. One problem is that there's no feedback on the GUI of which color you had selected, and the color choice is not saved between restarts (it always starts up as Red). I'll work on making it more user-friendly eventually but hopefully this lets you do some of your testing at least.
Let me know if it works for you guys. Thanks!
New version here, as usual:
http://www.pier13.com/projects/frc/virtualds/
  #35   Spotlight this post!
Unread 26-03-2009, 11:56
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Oh snap!!! I just thought of a HUGE advantage to having this virtual DS.
Some times in the rush to get out of the pits and into the queue, we forget to charge our pneumatic system to full capacity. Since don't have power to the real DS in the queue area, having a virtual DS on the laptop we already bring to the field would allow us to charge our pneumatics in queue.
Quick question -- how does the virtual DS handle the data returning from the cRIO -- i.e. the small customizable packets received during a match?
2017 Scoring Model
CAD Library | GitHub
  #36   Spotlight this post!
Unread 26-03-2009, 12:09
Software Engineer
Rookie Year: 1995
To the best of my knowledge it handles it just like the real DS. If you have stuff that shows up on your DS LCD, you can see that in the Virtual DS as well (you can use F1 to toggle between the main DS screen and the secondary, custom screen). DS digital outputs that are controlled by the robot show up on the GUI, and anything else is dashboard data, which the Virtual DS sends to the Dashboard IP, so if you have your Dashboard connected you should see that work.
Right now the IPs that it uses are fixed (it expects the computer the DS is running on to be 10.x.y.5 and the Dashboard to be 10.x.y.6), but it is possible to assign BOTH of those IP addresses to the same laptop which means you can run the Virtual DS and your Dashboard on the same computer. See this page for some instructions on how to do this.
  #37   Spotlight this post!
Unread 26-03-2009, 12:11
Really? I have been running both on 10.1.25.6, no problem.
  #38   Spotlight this post!
Unread 26-03-2009, 12:13
Software Engineer
Rookie Year: 1995
Well, actually my software doesn't care, but I thought the CRIO would only send packets back to the 10.x.y.5 address. I could have sworn I saw this when testing, but maybe something else was goofed up. I guess I'll have to try it again with it set to some other IP.
  #39   Spotlight this post!
Unread 09-04-2009, 18:06
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
The cRIO will always reply to the first IP address it receives a DS packet from (until reboot). Perhaps when you tried it you didn't reboot the cRIO after changing the laptop IP.
-Joe
  #40   Spotlight this post!
Unread 09-04-2009, 18:37
Software Engineer
Rookie Year: 1995
Yeah, that's probably it. I'm sure I had the robot connected up to the real DS before trying the virtual DS.
  #41   Spotlight this post!
Unread 13-04-2009, 11:09
GeorgeMitsuoka GeorgeMitsuoka is offline
Mentor, Robot Mag Technical Editor
FRC #3200 (Raptacon)
GeorgeMitsuoka has a spectacular aura aboutGeorgeMitsuoka has a spectacular aura aboutGeorgeMitsuoka has a spectacular aura about
This looks very cool. Can anyone answer this question: Is there any way to use the cRIO w/o the driver station (or virtual driver station)? I'm assuming the answer is 'no' as this could create a safety issue. The reason I'm asking is that we'd like to use the cRIO as a controller during the off season for an autonomous robot project and it would be better if we didn't have to tether it to a driver station or PC.
  #42   Spotlight this post!
Unread 13-04-2009, 11:28
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
I'm fairly certain that you aren't limited to using the basic and advanced software frameworks. You should be able to use a "clean sheet" and design the software to do whatever you'd like. The benefits of the frameworks are obvious - easy DS communications, "functions" for teleop vs. autonomous, watchdog "petting", etc. - and you really should use them as a starting point but you can use a "clean sheet". You'll definitely want to borrow the "watchdog petting" software otherwise the FPGA will disable your outputs.
Speaking of the FPGA, it is probably completely locked down. But you should be able to generate your own TCP/IP or UDP packets of info when you're operating outside of a FIRST event, link to other networks, go fully autonomous...
Have fun!
Russ
  #43   Spotlight this post!
Unread 13-04-2009, 11:29
You hit it on the head. With an FRC image loaded, you can not run the cRIO independent of a DS of some sort.
You could load a non-FRC image, but this would be considered an advanced (and possibly unsupported) use case.
  #44   Spotlight this post!
Unread 13-04-2009, 11:52
I probably should have added the same comments from Eric to my response. Basically -
Try whatever you want but if you try to shove more data through WiFi, the field will stop you (during FIRST competitions). And don't try to fool with the safety features in the FPGA and Ethernet communications packets since the field will stop that as well (also only during FIRST competitions).
Russ
  #45   Spotlight this post!
Unread 13-04-2009, 23:42
Burmeister #279's Avatar
Burmeister #279 Burmeister #279 is offline
What Time Is It?
AKA: Nick Burmeister
FRC #0279 (TechFusion)
Burmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of light
Send a message via AIM to Burmeister #279
Dave,
[note: didn't dl your program, not on my team machine] Have you thought about allowing the hotkeys such as stop and change color to be changed?
~Burmeister.
WHAT TIME IS IT? TWO SEVEN NINE!!! [Team B =) ] Awards: 4 Safety, 2 Ind. Design, 2 Xerox, 1 Nat. Champs
2009 Buckeye Semi-Finalists (1014 & 695) || 2008 GLR Safety Award || 2006 GLR Safety Award
2005 Buckeye Regional Champs (67 & 274) & GM Industrial Design Award & Safety Award GLR Quarter Finalist & Xerox Creativity Award & Safety Award National Xerox Creativity Award & Curie Quarter Finalist (1126 & 180)
2004 Buckeye Delphi Driving Tomorrows Technology Award & Quarter Finalist GLR Champs Nationals Curie Division Finalist
2003 GLR GM Industrial Design Award || 2001 National Newton Division Winner & National Champions
2000 MI DaimlerChrysler Team Spirit Award
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
Inputs on Driver Station z2daj C/C++ 8 16-02-2009 04:12
Dead Driver Station? tdeprince FRC Control System 3 12-02-2009 12:14
Need Driver Station dekker120 FRC Control System 2 02-02-2009 12:59
