Go to Post "Who needs finesse when you have air pressure?!" - neelpatel1710 [more]
  #61   Spotlight this post!
Unread 26-03-2009, 10:23
Team 135 Team 135 is offline
FRC #0135 (Penn Robotics)
Team 135 will become famous soon enough
Re: Methods of adding ballast to underweight robots
I know at the midwest regional there was a team filling water bottles with sand. This is a great way to do it because you can evenly distribute the weight across the bot.
  #62   Spotlight this post!
Unread 26-03-2009, 11:42
At L.A., one of the robots we reinspected for eliminations had made a modification: They'd put diving weights on their robot as ballast. They're in Sacramento this week, probably with said weights still aboard.
  #63   Spotlight this post!
Unread 26-03-2009, 12:14
Anthony,
Yes, that was the case, but the teams in question had to add additional material to satisfy the lead inspector, namely sealing the bottles with super glue, wrapping entirely with layers of tape and mounting in a very secure manner inside the frame of the robot where they could not be touched by robot collision. Repeated trips to the pit to re-examine the ballast were required as even a small amount of sand would have changed the frictional forces of the floor. In looking back, I am not sure that was the best decision. Although there were no spills, I felt uncomfortable about it the rest of the weekend.
  #64   Spotlight this post!
Unread 26-03-2009, 12:46
Anthony,
Thank you for that clarification, I knew that they did it, but didn't know how that looked from an inspection standpoint.
  #65   Spotlight this post!
Unread 26-03-2009, 13:19
For anyone reading this, any modification to the robot after the initial inspection requires a reinspection even if you are removing something. All inspectors would prefer that you contact them prior to making changes especially adding weight. Inspectors have a variety of ideas on specific changes and their impact on your robot and team play. Adding weight of the type described (kitty litter, sand, shot, ball bearings, etc.) should be discussed with the inspector prior to adding them even before your initial inspection. Inspectors need to discuss these things with the FTA and Head Ref as well so there is no surprises when you get on the field. Again a reminder on lead of any kind...it must be sealed (i.e. painted, dipped, etc.) prior to bringing to an event and may not be machined in the arena, i.e. no drilling, cutting, filing or breaking.
  #66   Spotlight this post!
Unread 26-03-2009, 14:13
Aren_Hill's Avatar
Build Nifty Things
The route we have went this year was by using 3/4" threaded rod with large washers on it, then just fine tuning the number of washers. They are solidly bolted down and cant really make a mess so it works well.
A guy who likes robots.
  #67   Spotlight this post!
Unread 26-03-2009, 18:28
jgraber jgraber is offline
jgraber is just really nicejgraber is just really nicejgraber is just really nicejgraber is just really nice
Originally Posted by Tazlikesrobots View Post
At the Dallas regional, there was a robot that used bags of cat litter for ballast. Basically it was a driving chassis with one of the kt tubs attached and two 20 pound bags of cat litter inside the tub.
They got the judges award
My recollection is that another rookie team with drive chassis, barbell weights, and a small scoop+kicker wheel got the judges award;
The Kit Tub bot rookie team was #3 alliance leader.
  #68   Spotlight this post!
Unread 27-03-2009, 09:09
Tazlikesrobots's Avatar
Tazlikesrobots Tazlikesrobots is offline
Jack of all trades...Master of none
AKA: Robert
FRC #1745 (P-51 Mustangs)
Tazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud of
Send a message via Yahoo to Tazlikesrobots
You are correct! I got the teams mixed in my head.... the team with the cat litter box took highest rookie seed!
It is all mind over matter....If you don't mind, it does not matter.
_________________
2006 Woodie Flowers Award Recipient - Lone Star Regional
2006 Rookie All-Star - Lone Star Regional
2007 Lone Star Regional Champions
2008 Quarter-finalist - Lone Star Regional
2009 Chairman's Award & Website Award - Dallas Regional
2009 Quarter-finalist - Dallas Regional
2010 - Xerox Creativity Award & Semi-finalist - Dallas Regional
Ballast Confusion Paul11 Technical Discussion 12 02-02-2009 15:12
Ok serious question ringo115 NI LabVIEW 2 24-01-2009 12:58
Ballast considered extra parts? Gabe Rules/Strategy 9 12-02-2007 10:47
Extra Discussion for Picture Discussion Ianworld Robot Showcase 1 31-01-2005 01:28
Serious OI problems Arrowsmith Control System 8 10-03-2004 14:36
