Go to Post Between reading the Manual, Q&A, Team Updates, the Blog, and Chief Delphi, you can be one of the most valuable members of any team. - Gregor [more]
Unread 26-03-2009, 16:10
Leg1t Leg1t is offline
FRC #2866
Leg1t is an unknown quantity at this point
Re: Where to get the metal from the chassis?
Also, we need four of these, any way to get them cheaper?
Unread 26-03-2009, 16:22
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
You can order pieces individually through AndyMark. Not sure if you want 4 complete kits, or just some pieces from all 4 kits.
You can also try to call AndyMark and see if you can sweet talk them to give you a deal... You never know...
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 26-03-2009, 20:08
FRC #2866
Wait, so 18 dollars pays for all four pieces (rectangular chassis)?
Or just one?
Unread 26-03-2009, 20:11
Zach O's Avatar
Zach O Zach O is offline
Building an iOS app @ glacial speed
AKA: @FRCZach
Zach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond repute
Andymark or Stock Drive Parts maybe?
Follow me twitter dot com slash frc zach
Unread 26-03-2009, 20:16
RyanN's Avatar
RyanN
From the AndyMark website:
6 of these items come standard in the C-Base, but only 1 is shipped per item purchased
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 26-03-2009, 20:24
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Or just one?
The pre-drilled c-channel is sold in individual pieces here. They also sell complete sets of the hardware for the c-bot chassis, minus wheels, transmissions, and chain.
You should check with other teams in your area, there is a good chance that teams that didn't use the kit chassis would give you or sell you their unused channel.
Unread 27-03-2009, 16:20
FRC #2866
Well if I wanted to search say ebay or something for this hardware, along what search terms would I use?
IE: "drilled aluminum?"
Unread 27-03-2009, 16:43
For the specific material you asked for, the search term is "C-Base". For similar material, "kitbot chassis" might give more results. A good place for you to get results would be CD-Swap (at least one other person is also looking for the same thing).
Maybe if you gave some indication of why you want it, you might get answers you can use instead of the answers you seem to be rejecting.
Unread 27-03-2009, 18:52
FRC #2866
Well its for a homemade robot. I am looking to rest a U shaped base of pine on it.
Heres a picture:
Obviously that doesn't look sturdy
So I am going to drill said holes in the aluminum to make them sizable for the rods. And rest the wooden chassis on it. And slide two triangles on each side to nullify the vertical difference.
I said it was for our bot because I thought it would yield better results.
It will have a caster btw
Unread 27-03-2009, 18:56
Happy Birthday! EricH EricH is offline
Ah. You want aluminum extrusion, but not necessarily the C-base?
Your local metal supply place will probably have some form of aluminum tube/channel. I believe that that is what you'll want.
Unread 26-03-2009, 17:57
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
You could try asking local teams if they used the Kitbot chassis or not. You would still have to account for it at full price on your Bill of Materials but the team may be willing to give the parts to you, trade for spare parts you may have or sell them to you at a lower price.
looking where to get 80/20 metal midway78224 General Forum 5 04-06-2008 12:34
Where to get metal Woody1458 Technical Discussion 21 10-01-2008 18:31
Hey, Where Can I Get That Animation From The Kick-off? DaBruteForceGuy General Forum 20 05-01-2008 22:50
dumb question: Where do we get the gear tooth sensors from? waialua359 Programming 6 30-01-2007 22:45
Which is Better metal or composite materials for the chassis Jared Rillings Rules/Strategy 3 13-01-2007 11:39
