Go to Post I think everyone just needs to chill out and realize what the real goal of FIRST is. - Koko Ed [more]
Unread 26-03-2009, 19:25
elbuo elbuo is offline
Teams #2884 and #1144
AKA: Yamil Asusta
FRC #1144 (Coquitron)
elbuo has a spectacular aura aboutelbuo has a spectacular aura aboutelbuo has a spectacular aura about
Creating a global variable
I'm really interested in learning how to create a global variable for 2 motors.
I've been trying to build it but I got no successful results.
I need it to use 2 motors in autonomous mode which I couldn't get to work in my regional because my coding wasn't correct
If someone can point me to the correct path I would really appreciate it.
Unread 26-03-2009, 20:01
Cuse's Avatar
Cuse Cuse is offline
AKA: Matt Mancuso
FRC #0175 (Buzz Robotics)
Cuse is an unknown quantity at this point
Re: Creating a global variable
A couple of questions...
1) What language are you programming in?
2) What is the variable for, specifically?
3) What about the code wasn't working?
Unread 26-03-2009, 20:50
You can add to an existing global file, or you can create another.
To add to an existing one, double click on one of the existing globals such as the Robot one in the template. Once opened, add more controls to the global file giving them good names. Then where you want to access them, you drag the global VI icon to the diagram and select the ones you just named.
If you want to create a new file, you can go to structures and drop the global? from the palette. Double click on it, drop the control with a good name, save, then click to change the ? to the global you just added.
Greg McKaskle
Unread 26-03-2009, 22:47
AKA: Yamil Asusta
I figured it out a couple of hours ago I just had to drag and drop :S Pretty simple!
Thanks a lot anyways!
Global news tonight? Mark Rozitis FIRST In the News... 16 28-03-2009 14:58
Global variable question Nathan Programming 3 27-01-2008 18:02
Global Variable Placement robbrad Programming 1 23-01-2008 00:50
Global Constants Ryan Cumings Programming 17 08-02-2004 19:05
