Go to Post You must have a base on which to stand. Knowledge is the base that wisdom stands on. - Steve W [more]
Unread 27-03-2009, 20:43
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is online now
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: When can the drivers step forward
This rule does not specfically state it, but it has been said in the drivers meeting that play starts with the clock, not the announcer or buzzer.
Same with the transition from auto to tele, but it is stated clearly here that auto ends with the timer displays zero and the following section says tele is immediately following auto.
<G01> AUTONOMOUS PERIOD - The AUTONOMOUS PERIOD is the 15-second period at the
start of the MATCH. PILOT control of the ROBOT is not permitted at this time. During this
period, the ROBOTS may react only to sensor inputs and commands programmed into the
onboard control system. All ROBOT safety rules are still applicable during the
AUTONOMOUS PERIOD. The AUTONOMOUS PERIOD ends when the arena timer
displays zero seconds left in the period.
<G02> TELEOPERATED PERIOD – The TELEOPERATED PERIOD is the 2-minute period of
game play immediately following the AUTONOMOUS PERIOD. At the beginning of the
TELEOPERATED PERIOD the OPERATOR CONSOLE controls are activated and PILOTS
may remotely control their ROBOTS. The PILOTS continue to teleoperate their ROBOTS
for the remainder of the MATCH. The TELEOPERATED PERIOD ends when the arena
timer displays zero seconds. This also indicates the end of the MATCH.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 27-03-2009, 20:59
nahstobor's Avatar
nahstobor nahstobor is offline
EWCP
AKA: Shan (pronounced Shawn)
FRC #2733 (Pigmice), FRC #612 (Chantilly Robotics)
nahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond repute
When the clock hits zero
Unread 27-03-2009, 21:40
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Yes do not go by the sounds especially when you go to ATL because at times you can hear another field's sounds too. Always go by the clock, now I'm not driving this year so i dont know if moving at 0 is okay or waiting until 120 like it sometimes has been in the past. For the most part this year the end of auton and begin of tele is so quick there isn't much difference between 0 and 120. Waiting that extra second my cause you to get a moon rock scored on you but thats only 2 points as opposed to 10 for the penalty
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 31-03-2009, 18:57
annie1939's Avatar
annie1939 annie1939 is offline
AKA: Ann Fairburn
FRC #4388 (Ridgebotics)
annie1939 has a spectacular aura aboutannie1939 has a spectacular aura aboutannie1939 has a spectacular aura about
Unhappy Re: When can the drivers step forward
We ended up getting a penalty for stepping forward and touching the controls before the bell. We were told that "to be safe " we shouldn't step forward before the bell ( not the buzzer.) It was announced the next day at the driver's meeting that the bell was the determining factor on when you could step forward. We knew we were right, but there is not much you can do when the head ref makes the ruling. Sigh....
Well , on to next year!!
Unread 31-03-2009, 19:06
The GDC made a ruling: It's when the clock hits zero. As soon as the clock hits zero, automode is over, no matter if the sounds have sounded or not.
http://forums.usfirst.org/showthread...8840#post28840
If the clock hits zero, and you step forward right afterwards, and you get a penalty for stepping forward before the bell, you might wish to show the linked Q&A to the head ref. Whether the ruling is changed or not in your case, you will get clarification, and possibly an overall change in how it's called at the event.
Unread 31-03-2009, 19:41
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
There's your official answer. It's been when the clock reaches zero for as long as I've paid attention to it, and the GDC has clarified it for us this year, so there you go. (:
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 01-04-2009, 14:37
annie1939's Avatar
AKA: Ann Fairburn
Yes. We posted the QA, but it was too late to help us. The driver had asked at the previous event to double check when he could step forward, and we knew we were right ,but you can only push so far. We ended up losing that round by a couple of points. We would have ended up in the top 8, but the alliance with SWIFT and TIN MAN would still have won the event so it didn't affect the outcome that much. It was just frustrating. Next year I will make sure all the drive team has the complete set of rules on their I- phones so that they could flash the rule to the judge. Part of the problem was not having the documentation on hand as they were making the challenge. We had the info in the pit, but that was too late. The kids did specifically ask at the drive team meeting the next morning, because we watched at least half the teams still going forward at the buzzer and not being penalized for the rest of Friday afternoon.
What is the best way to handle a situation where you have challenged the call and been refused yet you find the documented rule shortly afterwards that shows you were correct? I know it opens a slippery slope on people starting to lawyer the rules, but standing up for yourself is also an important skill to learn. We ended up just asking specific questions in the meeting the next morning for clarification. Luckily for us, the penalty occurred at our last match on Friday so we didn't have to worry about it again, but I think Gracious Professionalism also means standing up for what is right. Should we have been more insistent? What if someone else had received a penalty for doing the same thing and we knew it was the wrong call? Was it our duty to stand up and support them? Are the winners now going to go to Atlanta and wait half a second for the bell because that's what they were told the rule was? We didn't raise too much of a fuss because we didn't want to NOT be seen as gracious professionals, but (and we are into philosophy here) was that the "right" decision? Does "gracious professionalism" mean never raising a fuss even when you know you are right? (Remember that question was not about this specific situation, but about life in general ) (Watch out ! I may start straying into questions about the meaning of life )
And I will admit that this rule seemed to be written vaguely. It talked about where you can be in Autonomous and Teleoperated Modes and when they end. But the GDC also issued an update about the 6 different phases of the game in Update #9 and that there was a "negligible delay" between the two modes. To me, that means a delay you can ignore, but maybe to the ref it didn't. Maybe he was reading the "autonomous disabled" and "teleoperated disabled" in update 9 as a period of time between the 2 modes where you weren't allowed to do anything. We couldn't find explicit instructions about when or how you could transition between the two modes. And since he was going by the sounds and not the clock, we couldn't find any info about that in our hurried perusal after the fact. "Immediately following" and "negligible delay" are not as precise as saying there is a 0 delay between the two so it was subject to interpretation.
But this situation does give me ammunition for next year when I tell the kids to memorize the rules. Maybe I will get nods instead of groans ( I can always hope !!)
On the other hand, the regional committee did the best they could in Denver considering we were shut down on Thursday by a blizzard. It really showed how important that Thursday practice day is. We had a lot of competition rounds where the robots didn't work at all because they didn't have that day before to work on them. I remember in KC ,even on the first week of regionals, it was rare not to have a working robot on the field because we had that first day to repair.
Unread 31-03-2009, 19:10
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
This is an excellent opportunity for a learning experience for your team. As a drive coach I have a small list of questions that write up beforehand and bring to the driver's meeting. If these questions aren't answered or asked by others in the driver's meeting I will ask them.
Here are a few things from my list for this year:
1. When can the driver's step forward?
2. Where exactly can a PS reach with the tongs? (I've seen various interpretations in whether you can reach outside the airlock or not)
3. Can the super cell be touched before 20 sec. if not removed from the cell rack?
Vex step-by-step builders' guide ManicMechanic VEX 0 14-07-2008 00:12
2 steps forward, 1 step back! thewhit General Forum 1 18-02-2007 23:17
The best thing you can do when reporting a problem .. Brandon Martus CD Forum Support 1 08-02-2006 07:46
When can we expect the 2004 VKOP? Or is it already available? Frank(Aflak) Inventor 7 14-01-2004 11:17
