Go to Post i wish ours was done so i could get some sleep - keagara [more]
Unread 29-03-2009, 12:56
techplex's Avatar
techplex techplex is online now
Blake B
AKA: Blake
FRC #4909 (The Bionics)
techplex is a jewel in the roughtechplex is a jewel in the roughtechplex is a jewel in the roughtechplex is a jewel in the rough
Wireless Connection issues
Hello,
After returning from the Boston regional, we wanted to hook up our robot for sponsors night. The driver station continuously says "no comm".
I knew that at the competition a FIRST volunteer had changed our WPA settings.
I reset the router and the bridge to factory defaults...
Then proceeded to follow the instructions to configure the wireless components.
After a successful configuration, while the Ethernet cables were still connected: pc > router > bridge i could, ping and access the configuration pages for each. When I disconnected the cable router > bridge, I could not see the bridge wirelessly. "No comm".
Without a teather the robot will not do anything.
Please Help,
2648
MHS Infinite Loop Robotics
Maine team 2648
Blake
robotics.sparks.net
Blake
Electrical, Programming and Design
Creator FRC Q&A 2017
Mass FRC Team 4909: The Bionics
Maine FRC Team 5122: The RobOTies (2014-2015)
Maine FRC Team 2648: Infinite Loop (2008-2011)
Unread 29-03-2009, 18:59
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Wireless Connection issues
Two things immediately come to mind, but you may have already tried these:
--Which order are you powering up the bridge and router in? Some teams experienced problems if they powered up the bridge before the router was fully initialized
--Have you tried checking the security settings on the bridge to make sure that they were, in fact, reset?
Good luck
--Ryan
FRC 766, 2015-, Mentor
Unread 29-03-2009, 20:05
The color orange triggers me
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
we've also had the same issue, starting right after the competition ended and the bot was back in the shop. Could it be something with how it connected to the field before and now theres no field to connect to?
Unread 29-03-2009, 20:38
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
You may also want to check the settings on your router. There is a button on both the bridge and the router that are designed to ease setup. Accidentally pressing either of these buttons can mess with the security settings on the unit. We accidentally did this on our bridge and had to set everything back up because of it.
Unread 29-03-2009, 20:43
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
But the robot does work tethered?
You might want to run through your settings, double check your SSIDs and IP addresses, and make sure your bridge is plugged into Port 1 on the cRIO. Sometimes it's good to have a second set of eyes look at it.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 29-03-2009, 20:51
I've encountered bridges that, when reset, did not go to the normal settings we usually expect.
Go through both the bridge & router settings in your browser and make sure of all the possible security settings, e.g., the bridge WPA should be disabled, as well as, the variety of security settings under "Advanced", such as, WISH and Wi-Fi Protected Setup.
Unread 31-03-2009, 11:32
RyanCahoon's Avatar
See this thread for instructions on the recommended way of resetting bridge security.
--Ryan
Unread 31-03-2009, 14:49
TurmoilX TurmoilX is offline
FRC #1296
TurmoilX is an unknown quantity at this point
1296 has the same problem, please lemme know if you find a solution.
Unread 31-03-2009, 14:55
An issue you should check out is your SSID on both the WGA and your router.
During SW inspection we had several instances of teams who hadn't set their SSID correctly on the WGA. We corrected it, but that means the team's SSID on the router at home will also need to be changed to match.
Your SSID should be your team number without any leading zero's.
Not: "0123", "Team 0123", "linksys", "The Robotics", or "My team rocks!"
Unread 31-03-2009, 15:07
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Has anyone tried removing the WPA encryption from the gaming adapter?
Unread 31-03-2009, 15:08
Yes.
Unread 31-03-2010, 16:18
mtfawcett2907 mtfawcett2907 is offline
Mr. Fawcett 2907
FRC #2907 (T-Rex)
mtfawcett2907 is an unknown quantity at this point
During the Seattle Regional, our team was able to use our 2GoPC successfully on Thursday. On Friday, when it counted, we had no communication with the field and were dead during the first two matches. We were able to borrow another PC and were able to compete in the remaining matches. We had to give back our borrowed unit so now we can't run wirelessly - our broken unit will run tethered. Anyone know if this unit is warranteed and how to get a replacement?
Mike Fawcett
Unread 31-03-2010, 16:24
FRC #0973 (GRR)
Something doesn't sound right here. You're not using the wireless on the Classmate PC at all during the event - it's always going over the ethernet (as if you were tethered). Were you doing ad-hoc to connect the bridge (robot) to the Classmate? Or were you using the wireless router as the access point?
2011: ???
Unread 04-04-2010, 21:18
NyCityKId's Avatar
NyCityKId NyCityKId is offline
That Weird Kid
AKA: Andre Dunkley
FRC #1601 (Quantum Samurai)
NyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to behold
Send a message via AIM to NyCityKId
My team was plagued with a similar problem throughout practice sessions and we couldn't figure out what it was until we got to competition and found out the the case of the cRIO was grounding out to the metal electronics case (I told them not to use metal -_-). Our cRIO still ran, but the bridge would keep timing out and it would have a hard time hooking up to our router. I don't know how much that helped, but good luck to you all the same.
Unread 04-04-2010, 23:14
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Check your ethernet port. The tab on ours broke so the field cable couldn't hold itself in properly. Solution? Electrical tape+extension cord
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Wireless Issues MacAddict FRC Control System 6 25-01-2009 20:58
Wireless Connection Problem jaustin FRC Control System 18 18-01-2009 13:41
Wireless Router Issues zim2411 Scouting 17 09-04-2008 22:24
USB DAQ Wireless connection? StevenB National Instruments LabVIEW and Data Acquisition 1 01-01-2006 03:49
Wireless Connection on Pocket PC - AEGIS and Odyssey sanddrag IT / Communications 2 07-01-2005 15:51
