Go to Post You never know when the GDC will slide in a rule about any robot with a laser must do a laser light show on the floor of the field or face a 50-point penalty :p. - EricH [more]
Unread 29-03-2009, 22:52
andrew418's Avatar
andrew418 andrew418 is offline
Master spy
AKA: Andrew
FRC #0418 (LASA Robotics; The Purple Haze)
andrew418 is an unknown quantity at this point
pic: 418 LASA Robotics 2009 -- Aristophanes
Unread 29-03-2009, 22:53
sprocketeater's Avatar
sprocketeater sprocketeater is offline
Robot-Generated Time Paradox
AKA: Alex
FRC #0418 (Purple Haze)
sprocketeater is on a distinguished road
Re: pic: 418 LASA Robotics 2009 -- Aristophanes
We're proud of this year's robot-we definitely learned the value of "KISS" this season...
I think our robot deserves the "Most Purple Award", don't you?
Purple Haze, FRC Team 418
Drivetrain Lead/Driver
"I know that you believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
-Robert McCloskey
Unread 29-03-2009, 23:35
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
It doesn't even look to have enough clearance to pick up balls, does it really squash them?
Unread 29-03-2009, 23:37
Alex Dinsmoor's Avatar
Alex Dinsmoor Alex Dinsmoor is offline
Are our seeding points over 9000?
FRC #0201 (FEDS)
Alex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant future
Send a message via AIM to Alex Dinsmoor
How does your robot work? It's the closest looking robot to my team's robot (201) that I've seen so far.
It is very purple indeed
'08, '09, '10
4 Years | 14 Competitions | 194 Matches | 119 Wins | 77 Losses | 2 Silver | 1 Gold
Unread 29-03-2009, 23:49
franklima260 franklima260 is offline
AKA: Frank Lima
franklima260 is an unknown quantity at this point
The roller system compresses the ball about 3 inches
Unread 29-03-2009, 23:59
AKA: Alex
Alex:
Essentially, there are two sets of belts connected to two rollers each, one set in front and one in back. Pickup, despite the appearance of not having enough clearance, works very smoothly (yes, it does squash balls somewhat) and either feeds into our hopper in the back or shoots out of the top depending on the situation.
The front rollers are powered by one CIMWalt, while the back rollers are powered by a CIMWalt and a FP Dewalt as well. We can empty our hopper in around 2 seconds.
In my opinion, one of our best features is our rotating turret with automated tracking, which is able to switch between targets that are in range and follow them accordingly. Another cute and useful function is that when a trailer is in range, the fire button lights up on the control board!
-Robert McCloskey
Unread 30-03-2009, 01:20
FRC #0201 (FEDS)
Originally Posted by sprocketeater View Post
Alex:
That's like ours, but better! We have two belts that feed to a rotating turret, but we don't have a hopper like you guys. Instead we use one compartment for everything.
And your camera program sounds awesome! Do you just automatically dump when you are in range?
And where is the camera?
'08, '09, '10
Unread 30-03-2009, 01:37
AKA: Frank Lima
the little black eye in the center of the hood
"Youth ages, immaturity is outgrown, ignorance can be educated, drunkenness sobered, but stupid lasts forever." -Aristophanes
Unread 30-03-2009, 02:17
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
definitely the most bullet-proof robot we have ever made. And not to disappoint, it is indeed totally constructed from wood, from the rollers to the chassis.
The belt system was designed from the ground up to have the belt speed be the same as the firing speed, causing the balls to move at extreme velocities though the entire system, and making for a very rapid reload and firing cycle. this allowed our robot to play a "running and gunning" strategy that worked effectively throughout the Lone Star qualifiers
Unread 30-03-2009, 10:16
Tazlikesrobots's Avatar
Tazlikesrobots Tazlikesrobots is offline
Jack of all trades...Master of none
AKA: Robert
FRC #1745 (P-51 Mustangs)
Tazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud of
Send a message via Yahoo to Tazlikesrobots
Congrats to 418 on their Chairman's award win at the Lone Star Regional! Are you guys going to Atlanta?
It is all mind over matter....If you don't mind, it does not matter.
_________________
2006 Woodie Flowers Award Recipient - Lone Star Regional
2006 Rookie All-Star - Lone Star Regional
2007 Lone Star Regional Champions
2008 Quarter-finalist - Lone Star Regional
2009 Chairman's Award & Website Award - Dallas Regional
2009 Quarter-finalist - Dallas Regional
2010 - Xerox Creativity Award & Semi-finalist - Dallas Regional
Unread 30-03-2009, 10:47
AKA: Frank Lima
yep
Unread 30-03-2009, 10:58
Onward through the fog.
Off topic for just a sec -
Frank, I wish you would post a photo of your 'wings' that you created and wear at demos...those are so amazing...
Ok, back on topic:
Aristophanes.
~ Helen Keller
(1880-1968)
Unread 30-03-2009, 14:03
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
I believe you guys have only slightly more purple than us this year...
But it's definitely close. We'll have to have a contest for that award!
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 30-03-2009, 21:05
andrew418's Avatar
Master spy
AKA: Andrew
We don't automatically dump when we are in range (we leave it to the discretion of the operator) but I believe we have programmed in the capacity to dump when in range and the turret is lined up with the trailer.
We also have built into our OI a tactile response to alert the operator to a belt jam. When our robot detects the belts not moving when they are supposed to be firing or intaking, the control panel vibrates with a buzzer. The operator can then reverse the belt direction to dislodge the jam.
LASA Robotics, Purple Haze, team 418.
Unread 30-03-2009, 23:00
AKA: Frank Lima
here is a link to an early prototype of the roller system
http://www.youtube.com/watch?v=nAqhuE6KqIk
Thank You 2354 & 418 - Dallas 2009 JVN Thanks and/or Congrats 11 19-03-2009 02:52
pic: Team 418 LASA Robotics '08: ZePHyr roboticWanderor Extra Discussion 8 06-03-2008 21:02
pic: LASA Robotics Tree Skirt JaneYoung Extra Discussion 25 29-12-2007 01:40
LASA Robotics Demo valiot FIRST In the News... 0 19-10-2007 00:49
pic: Powerful Drivetrain - 418 leeweek Extra Discussion 6 10-04-2007 19:18
