#106
Re: how many people have had failing jaguars
We had one die for no obvious reason today. Worked in the pits, then once we got on the field, nothing. No light, good power, good pwm. Luckily, we had a spare already mounted and wired to the distribution block.
#107
2 Regionals, 27 regular matches, and over a dozen practice matches and all three of our Jags are still running strong.
#108
854 toasted one on the practice field minutes before a match 1075 was set to play against them in Waterloo... I helped them swap it. I wanted to beat them on the field, not off it. (We did... 64-30)
#109
Ours died rather early in the build season. A stroke of luck, considering what I've been hearing and reading from other teams.
#110
We had one fail during a match at the Dallas Regional. Thankfully our design incorporates a redunant system and we were able to continue in the match with one dead speed controller!
#111
Re: just wondering
Ours failed at Cleveland- we we pulling x amount of current through them and for some reason they would shut down. The Luminary Microsystems rep couldn't offer an explanation why. This happened twice, so we pulled them and replaced them with victors and have not had a issue since.
#112
From what I understand a lot of people have been blowing up Jags this year. One cause that I heard was common was that when you sent either a 1 or -1 value from the joystick to the motor the jags would blow up. Although this was an easy problem to fix (just set the values to .99 and -.99) our team opted out of using the jags this year because this was all unknown and we figured "why not use the extra victors we have lying around while we still can."
Hope I could help ![]() |
#113
Yeah, victors are smaller, and less breakable. But jags are smoother and offer so many more options.
#114
We blew out a jaguar after 5 tries using our winch to lift ourselves up.
Swapped it with a victor and no problems since then. ![]() |
#115
Do you have any explaination why, or is this just imperical data.
#116
We dont have any explanations other than the fact that after repeated tries, no problem since, all else the same.
#117
We just blew one of our Jags about an hour ago. It started smoking, a part melted inside, and now it only drives in one direction. We'd rather not request a new one from TI, so if anyone from the GTA has a spare, we'd greatly appreciate it if you sent it our way.
#118
Frankly, I was 'down on Jags' until I sent 2 back, and experienced their tech support. |
#119
Revus - I'm not sure why you wouldn't want to send it back. They'll replace it for free with no hassle (unless you did something insane like drilled a hole through it).
#120
1075 smoked 3 Jags on ship day (Black Jags, too). Can't see any particular reason why. We're working on getting them replaced.
| How many teams had router problems? | darkember | Technical Discussion | 8 | 31-01-2009 21:22 |
| How many people like bumpers? | diesel | Rules/Strategy | 53 | 24-01-2008 15:30 |
| How many people like bumbers? | diesel | Rules/Strategy | 3 | 18-01-2008 17:34 |
| How many people get on CD at school... | Ashley Christine | Chit-Chat | 37 | 21-06-2005 13:14 |
| how many of u actually used the stacker if u had one? | HolyMasamune | General Forum | 21 | 14-04-2003 13:12 |
