Go to Post Which meant that I was completely unprepared when the congealing large globules suddenly accelerated back towards me at 64 ft/sec/sec. - dlavery [more]
Unread 30-03-2009, 18:41
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Globe Motor Durability Versus RS-545
Just wondering what everyone's experience with Globe motors is, preferrable in comparision with the RS-545. Some old data says the Globe is a 55w motor versus what some say is a 100w RS-545. However the Globe may be extremely conservatively rated given it is intended for applications that required 10+ year life. It does not have even a slot for air cooling of its brushes but maybe its brushes are way bigger and more rugged than usual.
Anyone pushed these motors at 8amp, 12 amps or higher ? Burnt any out ?
My experience with the RS-545 is if you start running close to 100w continously (8+ amps), you should have a cooling fan pointed at the brushes and you probably shouldn't expect a motor (brush) life of too long. But then a complete regional might only put on 40 minutes total use on the motor.
Globe Motor RMS11 Motors 7 01-07-2008 20:36
globe motor chrisinmd Motors 9 11-02-2006 10:58
Globe Motor archiver 2001 0 24-06-2002 03:09
Globe Motor archiver 2000 4 24-06-2002 00:15
Globe Motor archiver 2000 0 24-06-2002 00:15
