Go to Post If you're the smartest person in the room, you're in the wrong room - Ian Curtis [more]
Unread 22-03-2009, 22:38
chopperdudes's Avatar
chopperdudes chopperdudes is offline
zizzling battery
FTC #0541 (Jaguars)
Team Role: Driver
chopperdudes is an unknown quantity at this point
Re: [FTC]: 121 Autonomous
Originally Posted by ttldomination View Post
Well, it's not that hard to implement. Let's say you're following a code, and something's not right. For example, if you're using a compass sensor, your sensor indicates you're not facing in the right direction or something, at that moment, your robot start counting encoder counts and angle measurements from the initial "alarm". After you no longer have movement or your encoders stop moving, then you simply perform the actions you did in reverse.
yes THAT would not be hard. but actually avoiding robots... can be quite hard... especially in this small space
Unread 23-03-2009, 02:01
dooey100 dooey100 is offline
FTC #3037
dooey100 is on a distinguished road
I was planning to do this if I got the time, and my plan was to have specific likely interference points. Then it would just go to something like:
if (interferenceDetected) {
//do something
} else {
//do something else
Unread 31-03-2009, 08:22
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Wink Re: [FTC]: 121 Autonomous
Originally Posted by dooey100 View Post
I
//do something
} else {
//do something else
Now "all" you need to do is figure out what code to include for:
"//do something else"
Were you thinking "Different Goal" or "Different approach to the Same Goal"?
Phil Malone
http://www.GEARSinc.org
Unread 31-03-2009, 11:50
FTC #3037
If we were interfered with as we attempted to put pucks in the goal, we would have tried to go around them. If we were interfered with as we attempted to collect the pucks, we would have dumped another of our opponents racks.
Unread 10-04-2009, 11:41
craig_yates craig_yates is offline
RingDingRick.com
AKA: Dylan Rodriguez
FRC #0121 (Rhode Warriors)
Team Role: Human Player
craig_yates is just really nicecraig_yates is just really nicecraig_yates is just really nicecraig_yates is just really nicecraig_yates is just really nice
Send a message via AIM to craig_yates
From our experiences, the ultrasonic sensors aren't reliable enough for accurate use in robot-avoidance procedures.
RingDingRick.com
AIR4H.org
Unread 10-04-2009, 23:10
595294001 595294001 is offline
FTC World Champion
FTC #2820 (Longhorn Robotics)
595294001 is an unknown quantity at this point
The other problem is that form the videos the code seems to take 29-ish seconds, leaving no time to retrace your footsteps even if you could.
[FTC]: Autonomous saaby FIRST Tech Challenge 8 19-02-2009 12:45
[FTC]: 121 Rhode Rage Pics and Videos Rick FIRST Tech Challenge 16 11-02-2009 17:21
[FTC]: Rhode Rage (FTC 121) is in need of a motor encoder wire Rick FIRST Tech Challenge 2 02-02-2009 01:56
FRC 121 and FTC 655 Déjà vu this past weekend Rick General Forum 2 03-03-2008 11:07
Video: FTC 3 Cloverfield Autonomous Synergy1848 Robot Showcase 0 26-02-2008 14:34
