Go to Post There's so much to say about a sponsor who gets involved and cares about your team over one who just signs a check. - galewind [more]
View Poll Results: Is it innovative and/or Efficient?
Innovative and Efficient 1 33.33%
Innovative 2 66.67%
Efficient 0 0%
Other 0 0%
No Opinion 0 0%
Voters: 3. You may not vote on this poll
Unread 31-03-2009, 10:13
Studentish Studentish is offline
FRC #2252
Studentish is an unknown quantity at this point
Exclamation Statistical Analysis for Targeting Control
Do you think that using Statistical Analysis based on the bell curve is an innovative and/or efficient way to implement targeting control?
Please explain.
Unread 31-03-2009, 10:53
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Statistical Analysis for Targeting Control
I think you're going to have to do a bit better at explaining exactly what you're talking about before anyone can give you a reasonable answer.
Unread 31-03-2009, 11:20
Originally Posted by Studentish View Post
Please explain.
Seconded.
A bit vague here. Specifics please?
Unread 31-03-2009, 11:56
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Why not go for the 1st/2nd order taylor series approximation aka basic kinematics approximation of your target's motion in the future few seconds?
But anyhow, perhaps by bell curve you mean randomly guessing firing solutions in a test environment then constructing a bell curve to help select (and interpolate?) a relevant firing solutiont from a table of known firing solutions at game time?
But a few more details would be nice.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 31-03-2009, 11:58
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Are you actually saying statistically-based algorithm or probabilistically-based algorithm? Statistically-based algorithms have been used by FIRST teams for a while, in the form of look up tables (I know several of the teams last year used similar things for ramping speed in autonomous and even for position control for knocking off track balls).
The ones that really interest me, and that I want to encourage my teams to start using since we have the power of the new control system, is probabilistic robotics, which is doing real-time analysis to calculate the probability of the robot being in any of several states instead of just using heuristic-based, "yes you are or no you're not," types of algorithms.
If this is the type of thing you're doing, I'd really like to hear more about it. Realistically, though, it's not that hard to do some of this type of thing with vision. I.e. you first do thresholding and then particle analysis, which gives you back several blobs, and you have to decide which one to track; in our experimenting, 1708 decided to use the size of the blob, as that is generally proportional to proximity to the robot. Note that this could be called probabilistic robots, because essentially we're assigning a probability to each blob that is the closest based on how big the blob is, because we don't know for sure, but larger blobs are more probable to be closer. Then we pick the largest blob - taking the blob with highest probability - as the one that we should "probably" track. You essentially have to do this with any algorithm that is analyzing data from a sensor.
The next step comes when you start interpolating data based on relative accuracy-probability from multiple sensors in order to estimate a higher state (for example is my DARPA Urban Challenge robot still on the road?). According to Thrun, Burgard, and Fox, this is the future of robotics and I'm inclined to agree.
--Ryan
FRC 766, 2015-, Mentor
Unread 31-03-2009, 12:15
Jared Russell's Avatar
Taking a year (mostly) off
In the realm of FIRST, "statistical analysis" done in real-time in any form is novel. In the realm of academic robotics, you'd have to be more specific as to what you mean, e.g. it sounds like you could be talking about a Kalman Filter (where you trade off between how much you trust your sensors vs. how much you trust your "model" of the world based on statistical properties of your sensor readings).
Unread 31-03-2009, 15:33
FRC #2252
Basic Details
Yes, I apologize for being rather vague, so here is a basic explanation of the idea from beginning to end.
The camera produces an image.
Labview renders out undesired colors, leaving desired colors (green or pink).
Generate the image onto the graph.
Use the standard bell curve to generate the numbers for the math required (standard deviation, kurtosis, ect.), also visa-versa for the other color.
Determine if the colors line up enough in the Y values to be one target.
Determine weather the target is indeed the right target (alliance).
Calculate the distance (based on preset values).
Possibly AI intelligence to track ahead of the target based on movement.
Calibration of ball release mechanism for proper distances.
Unread 31-03-2009, 18:13
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
YES!
With the power of labview and the control system, plus the vision sensor and any other costum efficent sensors can deffinatly allow programmers to go wild and do this challenge. It's such a big acheivment when it is proved working. I wanted to try to do something close to that (not really with probablites, but close enough) but because of lack of time, resources and other stuff (and the fact that our turret does not turn on it's axis [or will it...?]), I had to stop all the work I've done on it.
It is really fun to do all the thinking and probabilties and stuff and I encourage anyone to stand up to the challenge for next year, unless anyone has done this year and I want to see every single detail of it.
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 01-04-2009, 00:31
RyanCahoon's Avatar
Re: Basic Details
Sounds like the basic idea of tracking to me. Generating algorithm parameters based on empirical testing of your mechanism is the usual approach to programming mechanical systems. A normal curve may in fact be a good model for your shooter, but at some point you'll still have to set arbitrary limits on how far out of alignment you deem to be "close enough" to risk taking a shot; whether these are sensor readings, z-scores based on sensor readings, probabilities based on some complex model that you apply to sensor readings, it all comes down to the fact that you have an imperfect system, and you'll have to make some judgment about what level of risk you want to assume.
On a different note, the idea of tracking ahead of the target has always interested me. I'd be more inclined to polynomial approximations as Qbranch suggested rather than some sort of AI algorithm. In general, I don't think you could get enough data to accurately train such an algorithm, as you'd have to have a different set of data for each robot/driver, and humans are unpredictable enough that I don't think you'd have much luck. Even other humans aren't that good at predicting what we'll do. In my mind, using a second order approximation always seemed to be the best to me. Reasoning: the control point for our systems is essentially the amount of power we're applying to the motors, which is essentially proportional to the amount of acceleration the robot we'll be experiencing, which is a second order parameter of the system. If you're acceleration is changing, there's not much sense in guessing at it, as you're not sure what the program/driver is doing. This is definitely something I'd like to start playing around with in the offseason.
--Ryan
[FTC]: Field Control Issues / Analysis billw FIRST Tech Challenge 3 12-12-2008 22:50
488 XBot PNW Statistical analysis, and results from friday matches Fred Sayre Regional Competitions 15 16-03-2007 22:02
A statistical analysis of the "autonomous advantadge" Greg Marra General Forum 51 25-03-2006 21:09
STAMP (Statistical Team Analysis of Match Performance) is off and running! Ethulin Scouting 6 04-02-2006 23:12
Statistical Analysis of Regional Competion Scores rourke Regional Competitions 9 08-04-2004 01:05
