Go to Post Put on shows. Start new teams, FRC, FVC, or FLL. It doesn't matter. But I know that being on the robotics team has given me some of the best memories of my life, and I wouldn't want anybody else to miss out on that. - irishninja [more]
Unread 26-03-2009, 17:14
Zach O's Avatar
Zach O Zach O is offline
Building an iOS app @ glacial speed
AKA: @FRCZach
Zach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond repute
Re: Autonomous patterns?
Originally Posted by Wayne TenBrink View Post
The Martian twins (70 & 494) use the camera to find, approach, and score 7 rocks in autonomous (very impressive).
They can track from their cameras. It seems effective for moving, but I've noticed some troubles when moving in teleoperate as to tracking.
Follow me twitter dot com slash frc zach
Unread 26-03-2009, 20:28
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire (on sabbatical))
There are robots that use the autonomous period to obtain empty cells (such as 217) and there are robots that use the autonomous period to load their robot up with moon rocks so that they have ~20 moon rocks to score by the end of autonomous. There are a lot of strategies that use the autonomous period in a constructive way.
Unread 30-03-2009, 23:23
NC GEARS's Avatar
NC GEARS NC GEARS is offline
AKA: David Carrier
FRC #1918 (NC GEARS)
NC GEARS is an unknown quantity at this point
We can pick up from the floor or receive rocks thrown from a PS. In autonomous we often drive from corner to corner and let the PS top off the hopper. We may try picking up an empty cell this weekend (but don't tell anybody - they're not even supposed to notice).
Then theres the tight spin, first done (that I know of) by BOB (85) at Traverse City on week 1 and now copied by many others (including us!).
Personally, I don't see the point of going straight. It just puts you in the scrum and makes you a target.
WAY TO TELL THE WORLD WAYNE! YOU MAY BE THE RULER OF WAYNE'S WORLD BUT NOT OF OURS! KEEP OUR SECRETS SECRET!!!!!!!
United States Coast Guard Academy
Class of 2014
Unread 31-03-2009, 07:11
Bandgeek80001 Bandgeek80001 is offline
FRC #2867
Bandgeek80001 is an unknown quantity at this point
I'll have to admit that our robot just drove straight out and did a slight right-turn to keep jams from getting too tight. (It also helped for pinning robots to our outpost...)
I did talk to someone from 234, and from what I understand, they have written a program that allows them to draw a line on a computer, and it compiles code for the bot to do the same thing. They really did seem to do well in autonomous...
Unread 31-03-2009, 13:54
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Spinning hasn't seemed that useful to me unless you have a robot that can really build up some RPMs. If you're not spinning very fast, the PS just starts timing the spin and tossing moon rocks in anyways. I saw a PS at LSR that would grab two rocks at a time and toss them when the trailer swung around, then grab two more rocks, wait... It certainly makes life more difficult for the PS, but it doesn't really make scoring impossible.
A better plan starting in the corners is to pull a slight turn into the long wall and drive to or just past your outpost. If you're a tall robot and you pull your trailer slightly past the outpost, you're nearly impossible to score on. The PS you started in front of is unlikely to make a half court+ shot, the PS in front of you isn't likely to score over the top of your robot, and the outpost PS isn't going to have the range or the vision to score over the mass of robots in center field. Granted, you're in trouble if the robot in front of you doesn't get out of the way, but he's going to be in more trouble in that case anyways.
Unread 31-03-2009, 14:00
GVDrummer's Avatar
GVDrummer GVDrummer is offline
AKA: Jake Hall
FRC #0216 (RoboDawgs OTL)
GVDrummer is on a distinguished road
Send a message via AIM to GVDrummer
216 does a figure 8 in autonomous mode and tends to pick up an extra 4-6 balls before telop. starts. Maybe gets 1-2 scored on by a good human player.
Unread 31-03-2009, 14:06
Techgirl675's Avatar
Techgirl675 Techgirl675 is offline
FRC #0675
Techgirl675 will become famous soon enough
Send a message via AIM to Techgirl675
As seen at Davis, there was a lot of success in a forward followed by backward spinning action as it was done by many teams. Another good one, by 604, was driving to the outpost area and they were filled up to be able to dump upwards of 15 or 20 balls at the start of tele-op. The final amazing one i saw, and i can't seem to remember what team it was, was a tracking one, it would follow and lock on to a trailer and be ready to dump in tele-op, they could even dump in autonomous, it was pretty cool.
Unread 31-03-2009, 14:27
Another one for the corners, if you have a human-loadable robot, is to pull along to your fueling station and get loaded up. It creates a difficult angle for your opponent's PS, and they may score a few, but nowhere near the devastation that would happen if you were right in front of them.
pic: CNC Patterns R.C. Extra Discussion 5 13-08-2008 15:36
Noticed any patterns? bjimster1 General Forum 20 22-03-2005 23:45
Patterns? Eric Bareiss Rumor Mill 24 02-04-2003 02:14
Autonomous Jestin Hashop Rules/Strategy 2 11-02-2003 19:24
