Fans for defense
Just wondering if any teams have tried to use a high power fan system defensively in this competition.
Re: Fans for defense
![]() If you want the specs, PM me. |
we considered using one but decided not to based on the fact that the balls have large holes in them.
edit: i just realized the mike from my team is the starter of this topic |
We did and they worked great, if done right. We were able to get between a robot and its trailer, turn on the fans and push a team halfway down the field by its trailer. Theres alot more to building the fans than just slapping a motor on a blade. My team did alot of research
heres a video of them running in the pit http://www.youtube.com/watch?v=Xnw7ieccNNc |
It depends on what you mean by "defense". We had two FP driven propellers on our bot that provided 6-8 lb.s of thrust. At one point, when our ball intake broke, our driver pushed 1319 (flash) all the way down the field sideways, to the human player, who then scored two super cells.
If, on the other hand, you mean using an air stream to deflect orbit balls, then no. We did some experimentation using a 3 hp leaf blower. While you could push the orbit balls around on the ground easily enough, we were not able to change the trajectory of an incoming orbit ball enough to make much difference. We decided that it wasn't worth pursuing. |
I know the robodawgs were trying, but i saw one of their team members walking around with it (wired to a switch and a battery in his backpack), it made a huge amount of thrust, but i really never saw it work.
#7
A bunch have tried. my favorite is 180, basically you went where they wanted you to go. On another note with our basket dumper we cant dump on them while this fan is running (from directly behind). You can throw balls in to the trailer though
#8
Second I feel I have to mention that I believe you were able to push us that way simply because our driver did not know how to maneuver out of it. Maneuvering out of it would have been possible and he was a rookie driver. The fans had nothing to do with it. Had you tried that again you would not have been as successfull. and Third if you guys keep posting your different strategies on here people our gonna know what to expect. I would be cool to see a team from the South even if you are on the "wrong side of the border" win it all but that will be more difficult if you don't keep some stratgy up your sleeve. Good luck |
#9
469 Las Guerillas is using 2 fans for thrust. I'm not sure how well its working i didn't see any huge differences, but it was pretty cool either way, cause they were very little of there weight, so they had a heavy complex shooter and storage aswell.
#10
I never said that they didn't in fact I agreed that they did. However this thread was about the effects that fans had and I just pointed out that fans had nothing to do with them accomplishing that task.
#12
2753 is currently fanless but they pin like mad.Last edited by Akash Rastogi : 31-03-2009 at 21:41. |
| For all the Billfred fans out there | ROBOmasta | Chit-Chat | 5 | 16-02-2009 11:58 |
| Looking for a rule - No defense on robots without tubes | Don Wright | Rules/Strategy | 53 | 12-03-2007 14:18 |
| Offense/Defense rankings for 1043 teams | Bongle | General Forum | 21 | 06-04-2006 19:58 |
| Back to Defense for a minute. | archiver | 2001 | 34 | 24-06-2002 03:57 |
