Go to Post It's a hunch, based on engineering intuition; there are too many hard-to-quantify variables to do any accurate calculations. Looking for some experimental corroboration or refutation. - Ether [more]
Unread 31-03-2009, 00:46
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
pic: 1323 2009 Bot
Unread 31-03-2009, 00:48
Re: pic: 1323 2009 Bot
Seriously? A fan? You've been talking to Sean too much
Where would it go btw and how much thrust are you looking for? Custom FP gearbox? CIMs? Details man! Details!
Bot looks so sick, very Poofesque with the paint.
Unread 31-03-2009, 00:49
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
I think I see a good spot....
Unread 31-03-2009, 00:53
Untitled Untitled is offline
AKA: LoongYi Tan
FRC #1671 (Buchanan Bird Brains)
Untitled is on a distinguished road
I think adding a shrouded fan would be a great idea. I personally thought that your bot wasn't too efficient when you guys were heavily defended against in davis. I think the fan would give you a leg up in those pushing matches. ^^
Unread 31-03-2009, 01:06
Heh, must've been decently efficient if it drew that much defense to it.
There's not many robots I can think of that can pull out of a tag team pin to the wall. Its tough. 330 did it before I think.
Unread 31-03-2009, 12:34
Techgirl675's Avatar
Techgirl675 Techgirl675 is offline
FRC #0675
Techgirl675 will become famous soon enough
Send a message via AIM to Techgirl675
in all fairness i think that this robot was quite efficient at Davis. While there, we found you guys to be a very good robot......but i have to say this, i'm engaged to your robot!
Unread 31-03-2009, 13:09
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
I see you guys have taken some battle damage, but it still looks drop dead pretty (something about that blue frame).
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 31-03-2009, 15:33
Woah I just saw that now that you pointed it out. What/who happened there?
Unread 31-03-2009, 17:57
Aren_Hill's Avatar
Build Nifty Things
I see you used the original 2 piece chain tensioners....
A guy who likes robots.
Unread 31-03-2009, 18:50
Andy L's Avatar
FRC #1458
haha I pointed this out at Davis, they ended up not make the AM chain tensioners for #25 chain. They used a lot of the AM ones on their manipulator and ball pickup
Unread 31-03-2009, 19:35
R.C.'s Avatar
Sean did finally convince me, we have about 4 lbs of dead weight on the bot. So why not add a fan for a tad bit more thrust. We are gonna get a fan between 15-22 inches; direct driven from a fp due to weight or maybe a 2:1 ratio off of the fp.
I was watching some of our matches and in about 95% of the matches we got pinned by two robots atleast once a match. It kinda sucked . Hopefully we can push with the fans
Yeah, I think Squirrel brought this part up. When ball collecting mechanisms collide with a part of the bot, it sometimes hits the frame. Good thing we built a tank
We didn't have enough time to machine the #25 series ones because they required some special operations and we just didn't have enough time. But we used a single piece of the AM #35 chain ones and made a slot for #25 chain. They are spray painted black and are used everywhere: the mast, the shoooter and the ball collector.
R.C.
MadTown Robotics Team 1323
Unread 31-03-2009, 20:15
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
picks up jaw, loves the look
Is now an engineer thanks to FIRST.
pic: 832's 2009 Robot "Taz-bot" Tom Bishop Extra Discussion 14 18-03-2009 17:23
pic: team 858's 2009 bot powerkane Extra Discussion 2 07-03-2009 12:45
pic: 1323 Final Bot 2009 R.C. Extra Discussion 5 20-02-2009 10:52
pic: Team 1305's 2009 Lunacy bot - R2-T2 Spencer E. Extra Discussion 9 17-02-2009 18:20
