Go to Post The teams who have the best chance at success are the ones who know where they can save time and money on machining by using or using part of some premade equivalent. - Bill Gold [more]
Unread 01-04-2009, 17:08
mutantblond mutantblond is offline
FRC #2523
mutantblond is an unknown quantity at this point
polyurethane tubing
after seeing some of the designs at our regionals, we would like to redesign our ball - lifting mechanism using the polyurethane tubing. Can anyone make a recommendation on sizing and/or type? We were told to get it from McMaster-Carr.
thanks,
elaine
Unread 01-04-2009, 17:15
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: polyurethane tubing
Hope this helps:
http://www.mcmaster.com/#round-belts...-belts/=19dc3a
You most likely want round urethane solid core belting.
Unread 01-04-2009, 17:17
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Team 234 uses McMaster P/N 59725K803. It is kind of expensive, but has lasted two comps with no problems.
In the future, searching may get you a quicker response.
Collin Fultz
Unread 01-04-2009, 17:27
HighLife's Avatar
HighLife HighLife is offline
FRC #0245 (Adambots)
HighLife will become famous soon enough
Send a message via AIM to HighLife
We're using the yellow 1/4 inch polyurethane shingle routhane tubing from McMaster. Make sure you buy the barbs that hold them together. Don't pay for the $300 welding kit or try to weld them yourself because you'll have belt failures and it's EXPENSIVE.
We have them cut about 10% shorter per foot to make up for stretch. We also have spans of no more than 1.5 feet between rollers.
We've had 0 belt breaks, so they work .
AdamBots.com- Winner of 7 Best Website Awards!
Unread 01-04-2009, 17:38
Aren_Hill's Avatar
Build Nifty Things
The kit is not necessary to weld the belts, it can be accomplished with a lighter, soldering iron hotplate etc, and when done with some care will not break on you
http://www.chiefdelphi.com/media/img...b7b10cca_l.jpg
see also the god of polycord:
http://www.chiefdelphi.com/media/photos/33403
all welded i believe, i'll let Adam chime in on that
yeah...lol its good stuff
A guy who likes robots.
Unread 01-04-2009, 17:49
HighLife's Avatar
We've had a few teams come to us and say that they've tried the lighter method and had belts break on them.
Pay a few bucks for the barbs and you'll save yourself time in the build process and stress later.
surferacf's Avatar
surferacf surferacf is offline
Student Leader & Electrical Captain
AKA: Aaron F
FRC #3060 (The Fighting Tuna)
surferacf will become famous soon enough
I second what HighLife said - The hollow core 1/4" McMaster-Carr Polyurethane Belting (6567K57) and the associated connectors (6567K22) are the way to go in terms of belting. Quick, easy, and relatively cheap.
(That bit about keeping the spans between rollers short is crucial to note as well - We had a 40" run and the bands flexed too much, even with cutting them shorter)
"Curiosity killed the cat, but for a while I was the suspect."
-Stephen Wright
Unread 01-04-2009, 17:52
We have spans of about 4 feet (80 total inches of belt) running moon roks from the floor to our top "hopper". On our practice bot, we did the "welding" ourselves. This is with solid core belting. Through hours of practice, we have had no problem with belts breaking. You just have to take your time and give the weld time to set. It can be done.
Collin Fultz
Unread 01-04-2009, 18:31
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
We used the 3/8 inch, clear, hollow core tubing and joined it with the barbs. We have had the barbs pop out, so we added duct tape after that incident, and haven't had any problems since. We are also using 3" diameter plastic pulleys for the 3/8" belting.
I had to manually create a key/set screw hole in 2 of our 4 pulleys on the drive shaft, but it was pretty easy to do, even with a hand drill.
Unread 01-04-2009, 18:39
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
mcmaster carr has several smaller sizes in stock and they ship in a day or 2. custom made lengths take about a week.
they recommend an 8 - 10% length reduction from actual dimension to belt, and there is a limitation on belt diameter and roller diameter.
we have been using both styles (our fab and custom made).
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 01-04-2009, 18:45
rspurlin's Avatar
rspurlin rspurlin is offline
AKA: Ray Spurlin
no team (no team)
rspurlin has a spectacular aura aboutrspurlin has a spectacular aura about
We used the green belting from McMaster and did the welds with a heat gun. The ones that failed failed long before we put them on the bot. However, knowing what I know now, I'd get the hollow tubing and barbs. It can be installed to replace a broken belt without disassembling your robot. Our runs this year were pretty long and because we wanted to make sure the bands did not flex much, we shortened the band by the recommended 8%. Our bands ended up too tight and placed way too much load on the motor. We probably destroyed a CIM that way.
Mentor(2007-2013) - Team 1379 - Gear Devils - Norcross, GA
2010 Palmetto regional Semifinalists, Judges Award
2010 Peachtree Regional Quarterfinalists, GM Industrial Design Award
2009 Palmetto Regional Finalists
2008 Bayou Regional Quarterfinalists
2008 Peachtree Regional Semifinalists
2007 Peachtree Regional Quarterfinalists
Georgia FRC Planning Committee
Unread 01-04-2009, 18:48
armyOFdarkness's Avatar
armyOFdarkness armyOFdarkness is offline
Lead Mentor
AKA: Adam
FRC #2039 (Rockford Robotics)
armyOFdarkness has a spectacular aura aboutarmyOFdarkness has a spectacular aura about
Send a message via AIM to armyOFdarkness
We use an industrial heat gun to weld the tubing together and put it in water to get it to set a little bit faster. You have to let it sit at room temp for 5-10 minutes and then the weld should be as strong as the tubing itself. It's incredible stuff, but I would reccomend experimenting with welding it together.
www.rockfordrobotics.com
Student Member, Team 706 (2001-2002)
Lead Mentor, Team 2039 (2007-Present)
2007 Wisconsin Regional Finalists (Thanks 930 & 2175)
2009 Midwest Regional Finalists (Thanks 135 & 2338)
2009 Wisconsin Regional Champions (Thanks 1625 & 2194)
Unread 01-04-2009, 18:50
HighLife's Avatar
Thanks for listing the part numbers and sorry, forgot to tell you about the span issues.
Unread 01-04-2009, 19:47
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
We welded them with a 120 watt soldering gun, with a small flat plate bolted to the tip. All welds were 'student destructive tested'.... the students could not pull them apart.
No failures at the welds.
Unread 01-04-2009, 21:08
Seat Ninja's Avatar
Seat Ninja Seat Ninja is offline
Still waiting for the boltstretcher
FRC #0686 (Bovine Intervention)
Seat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of light
Send a message via AIM to Seat Ninja
We used the Mcmaster-carr hollow 1/4" belting that was mentioned before. It worked well for us and none of the barbs pulled out. I think it was worth it to use the hollow belting because you can run the belts while the rollers are mounted on the robot. With the welded ones, you have to remove all the rollers if one belt snaps for what ever reason. Also, I saw other teams who had solid cord on their 'bots and unless the team used a welding kit or similar, the welds would be blackish/discolored and the heat would deform the belts slightly causing them to bump around and not be as aestetically pleasing. Pretty much the hollow cords look cleaner when done quickly and are easier to adjust. My $.02
Can you play Crysis?
Pneumatic Tubing Magnechu Pneumatics 6 28-01-2008 21:44
pneumatic tubing Matt21q General Forum 1 19-02-2007 20:05
Curley Tubing natis Pneumatics 5 20-01-2007 18:22
Tubing In Autodesk unapiedra Inventor 13 24-05-2005 11:59
Tubing pfortunejr Technical Discussion 6 11-01-2002 08:10
