Go to Post You are what this world needs: a hero kids of all ages and backgrounds can look up to. I am a better person today than before I met you, because of how you touched my life. I thank-you. - Paul Copioli [more]
Unread 01-04-2009, 19:14
drhall drhall is offline
Winner 2009 West Michigan Regional
FRC #0216 (RoboDawgs OTL)
drhall is an unknown quantity at this point
Send a message via AIM to drhall
Scouting Sheets
Hello,
Looking into redoing our scouting sheet
Any thoughts on what areas should be on a scounting sheet.
Thank you for any input you make have.
Dan
Unread 01-04-2009, 19:31
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Re: Scouting Sheets
i know we have in the past looked at mainly numbers. Like number of balls scored/attempted, HP balls scored/attempted, EC's ran to HP, SC's Scored. In previous games we'd look more at autonomous routes.
This is my first year in the stands, but what I've been looking at is speed and consistency. You could be a really fast scorer but if nearly all the balls end up on the ground that’s not good, and also a very accurate robot that is slow is not so good either; differences raw numbers sometimes fail to pick up. I would make a note of teams that failed to move during auton, or entire match. Look for jams and failed mechanisms. Then I'd try to the best of my ability unbiasly rank the teams based on speed for different parts (i.e. a shooter/dumper was fast, but their loader was slow). Then i could use this data with the others that have more of the raw data to help make a pick list.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 01-04-2009, 20:05
JHay's Avatar
JHay JHay is offline
Need a Dispenser there!
AKA: That One Guy
FRC #1918 (NC Gears)
Team Role: Scout
JHay has a spectacular aura aboutJHay has a spectacular aura about
Send a message via AIM to JHay
Lightbulb Re: Scouting Sheets
Also, you should have their actual autonomous patterns written down. This could help you coordinate strategies if your on their alliance, or find out how to counteract them if they are on another alliance.
Although it isn't relevant in most cases, starting positions are good to track where teams do good and bad when they go into autonomous. (i.e. A robot that goes straight in autonomous would not do so well if in the center. They would just run right into the other side...hard.)
I agree with bigbeezy that the success rate for the amount of moon rocks made into a trailer will help you determine your better offensive robots.
Defense capability should also be marked down as it is now becoming increasingly common (at least in FiM) that many teams need someone to help *cough* "nudge" opposing robots away.
I'm on a boat!
Unread 01-04-2009, 20:28
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
Re: Scouting Sheets
I'd leave lots of room for notes and comments.
Maybe that much room.
I also read something about an unmarked check box at the bottom of the page called the 'jerk box'. Most teams want to keep that box unchecked.
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 01-04-2009, 20:34
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Re: Scouting Sheets
The most important statistic, by far this year, is how many balls are in the teams trailer at the end of a match.
If you want to go by pure numbers, that's my favorite number to look at. Then it goes on to speed, scoring capability, and ball pick up ability. All of which are qualitative rather than quantitative.
Another thing, this year, wide robots tend to be more maneuverable, so they automatically get a bonus in my book. Along with swerve drives.
If opponents can't score on your teams trailers, you win. Easy as that.
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 01-04-2009, 20:49
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
Re: Scouting Sheets
It's important to leave room for both qualitative and quantitative analysis. While it's good to know that Team A has 85% in scoring, it's also good to know that you can demolish them by bumping them in the rear right corner. I'm going to link you to what one coach likes to see from her scouters, though I'm sure there are many other possibilities that are equally as good if not better. Hopefully you'll at least get some ideas from that. (Sorry for the outside link, but it was a lot to paste in.)
Edit: Also, I'm not sure if this is something you can specifically scout for from the stands, but by interacting with teams through pit scouting, and talking to your coach who has worked with teams on the field, please check up on teamwork. If a team has a great robot, but is unable or unwilling to work with other teams, achieving success with them will be very difficult. Look carefully at how they interact with others, and if they are willing to compromise to bring success to the entire alliance.
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 01-04-2009, 21:14
JDM JDM is offline
programming lead; team executive;..
FRC #2199 (Robo-Lions)
JDM is on a distinguished road
Re: Scouting Sheets
Team 2199 keeps a very simple scouting sheet, which allows us to recall specific traits about each robot to go along with team members' general observations. It works well for us, but if you don't have several people who stay generally aware of the teams and how their robots are doing then it might not be best. If you have lots of scouts it might be better for you to go with a complex system that simply gathers lots of data.
For pit scouting, there's a series of yes/no questions that reflect traits we would look for in alliance partners, a ranking for team attitude, and a large space for comments. Simple questions like "do you have an autonomous mode" narrow the amount of teams that we consider quite easily, and team attitude also plays an important part of it.
As for field scouting, go with whatever you think is important to you. Our sheets had 1-5 rankings with general categories reflecting the robot and HP's skills in maneuvering and delivering cells, as space for win/lose, penalties, and comments. It was then entered into a spreadsheet later for analysis.
Since I'm talking about it here, I really have to take the time to thank our head scout who came up with this system once again. Without this, we couldn't have done so well.
Unread 01-04-2009, 21:25
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Scouting Sheets
We made up pretty simple scouting sheets this year
Unread 01-04-2009, 22:28
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Scouting Sheets
We used a largely paper based scouting system this year it will probably migrate slowly to computer based but paper and clipboards I can safely hand to freshman.
Our pit scouting sheet was a series of basic check the item that is appropriate for this robot.
We kept human player and robot data separate to make it easier to organize. For human players we looked at penalties, shooting percentage, range, and super cells. The robot data was more complex so we could get a better picture of the robot/drive team as a whole not just does it score a lot and does it get scored on a lot?
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 01-04-2009, 22:45
roboraven15's Avatar
roboraven15 roboraven15 is offline
FRC #1188 (Oaktown Crewz)
roboraven15 is an unknown quantity at this point
Send a message via AIM to roboraven15
Re: Scouting Sheets
definatly you cannot forget how many balls are in your trailer at end of match. its a stat not always looked at, like a team at the last competition was a good scoring robot puting lets say 15 balls into trailer each match. only problem with them, they averaged prolly 20+ in there own.
Unread 01-04-2009, 23:32
rogerlsmith's Avatar
rogerlsmith rogerlsmith is offline
Software Engineer
AKA: Roger Smith
FRC #3357 (COMETS)
rogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to behold
Re: Scouting Sheets
We are looking a lot at scoring averages. A quick way to get this info is to use the "Lunacy Scout" at http://www.firstobjective.org. Type in any team number for a complete analysis. We are putting this info right on our scouting sheets before the matches begin.
Roger Smith
Mentor - FRC Team 3357
COMETS - Creating Outstanding Minds, Embracing Technology & Science
Share FIRST videos, photos and experiences at FIRSTObjective.org
Unread 02-04-2009, 13:00
prettycolors91's Avatar
prettycolors91 prettycolors91 is offline
Robotic Systems Enterprise Director
no team (Robotic Systems Enterprise (HOT 67 Alumni))
prettycolors91 is a splendid one to beholdprettycolors91 is a splendid one to beholdprettycolors91 is a splendid one to beholdprettycolors91 is a splendid one to beholdprettycolors91 is a splendid one to beholdprettycolors91 is a splendid one to behold
Re: Scouting Sheets
One of the most important features of our sheets is the mini-field diagram. Scouters draw the course of the robot during autonomous, and over the course of the regional, the strategists/drive team can discern a pattern in a team has multiple autonomous programs. We also assign about 4 kids to a robot, which allows them to count how many shot as opposed to scored, the accuracy of the human player, speed, amount scored on, etc.
Team 67 HOT - Alumni
Teams 857, 2586, 3771 - Mentor
Robotic Systems Enterprise -Director
Michigan Technological University
Unread 02-04-2009, 13:32
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Scouting Sheets
Scouters also need to talk to the drive team after every match. What is important is, how well did each team work with your team? did they listen to your suggestions? Did they do what you asked of them? Did they ask you to do something that did/didn't fit well with your bot/strategy?
The best team in the world is useless if it doesn't fit into your strategy or meld with your strengths.
Former Mentor Team 1771
Former mentor Team 4509
Unread 02-04-2009, 20:55
Anders Horn Anders Horn is offline
FRC #2557
Anders Horn is an unknown quantity at this point
Re: Scouting Sheets
I ran the numbers and it doesn't look like #of balls in your trailer has any predictive power at all.
Unread 02-04-2009, 20:56
MrForbes's Avatar
AKA: Jim
Re: Scouting Sheets
That's interesting....even if you're a no-show?
paper: Team 3062's Scouting Sheets Mew187 Extra Discussion 3 06-02-2009 13:36
paper: Martian Scouting Sheets JackN Extra Discussion 6 18-02-2007 23:54
Scouting sheets SoccerNerd36 Scouting 6 24-01-2005 19:27
scouting sheets DLyons Scouting 1 14-02-2003 13:05
Team 93 Scouting Sheets Tyler Olds Scouting 1 11-02-2003 22:31
