Go to Post "I don't need an anniversary party. Use the money for the kids on the robotics team."- Walter Suchowiecki, BMS technician - Wayne C. [more]
Unread 01-04-2009, 21:16
RyanS's Avatar
RyanS RyanS is offline
Team Captain
AKA: Power Driver
RyanS has a spectacular aura aboutRyanS has a spectacular aura about
Re: polyurethane tubing
I would recommend the 1/4" solid core McMaster-Carr Polyurethane Belting. We used it on our robot this year for the first time.
http://www.chiefdelphi.com/media/photos/33401
For all of the people that have had problems with their welded joints failing, I have a feeling that you are not melting the Polyurethane Belting enough. We tried welding with a hobby hot knife and soldering Iron with flat tipped blade, but found that it was only melting the edges of the belting. For the belts on our robot, we used the the blue flame of a candle (the orange flame will char the belt leaving ugly black marks). We then took the hot knife and smoothed the polyurethane that squeezed out of the joint (My mom calls this frosting the joint).
As others have said there is no need to buy a jig. We made our own jig by putting a 1/4" slot in a piece of 1/2" thick aluminum stock. The aluminum acts as a big heat sink too.
We bought a considerable amount of extra belting because we had heard of failures. Fortunately we have had no joints or belts break.
Ryan
2010 Los Angeles Finalists
2010 San Diego Regional Winners
2009 Los Angeles Regional Finalists
2008 San Diego Regional Winners
2008 FTC World Champions
Unread 01-04-2009, 21:30
EgROS's Avatar
EgROS EgROS is offline
AKA: Eric Gros
FRC #0624 (Cryptonite Robotics)
EgROS is an unknown quantity at this point
Originally Posted by HighLife View Post
We've had a few teams come to us and say that they've tried the lighter method and had belts break on them.
Pay a few bucks for the barbs and you'll save yourself time in the build process and stress later.
We used a simple fusing technique and have never had any belts break on us despite attempting very hard to do so. We created a simple mold by drilling a hole through a delrin block then cutting it into two halfves down the center of the hole. We then heated the two ends of the cord with either a lighter or soldering iron, placed it in the mold and applied presurre for about a minute.
TEAM 624 - CRyptonite Robotics
Unread 01-04-2009, 21:42
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Welding the solid core takes a little practice to perfect, but once you get it down it will not break. We've found that once you melt the ends together and wait five minutes, if you pull on the joint really hard and it doesn't break, it won't break on your robot.
Art Dutra IV
世上无难事,只怕有心人.
Unread 01-04-2009, 22:59
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
We welded the solid orange polychord with a standard propane torch.
Just melt both ends that you want to connect
Place them in a piece of Angle Aluminum, with the two ends in contact.
Hold for 5-10 minutes till cool.
This resulted in a weld that was strong enough that two people doing tug-of-war could not rip it.
The welds might not be the prettiest, but they work amazingly, and don't jump off of our pulley's
If I remember correctly, the polychord on our bot had a tension of somewhere more than 30%. (I think I remember it being 35%, but I might be wrong.)
Unread 01-04-2009, 23:05
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
We used the orange solid core from McMaster, heated both ends up with and clamped it with an old ribbon cable crimper that had some small angle added to it. to keep things lined up.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 01-04-2009, 23:53
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Here are some intersting tables on Rounthane. Notice that you can see the extra load the stretching will put on your motor, which guided us into our new conveyor motor setup for Atlanta. Previously, we just guestimated everything with conjectures that a motor would or would not work. This data, PINK's recommendation, and the lack of necessity to weld the belting are all of the reasons we're redoing our conveyor with it for Atlanta.
Quick question though -- is the polyurethane cord on McMaster the same as the Rounthane? Usually mcmaster mentions the brand name, if there is one, in the product details.
GitHub
Unread 02-04-2009, 00:04
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
If you are attending nationals, you can find 744 SHark Attack. We used a lot of belting this year and Ralph, our electrical lead, is an expert belter. He does almost all the belting at him company. Feel free to stop by, we melt them simply and they have not broken for us yet.
www.sharkattack744.com
Unread 02-04-2009, 00:25
Johnny's Avatar
Johnny Johnny is online now
We do it for the pizza
FRC #1266 (The Devil Duckies)
Johnny has a spectacular aura aboutJohnny has a spectacular aura aboutJohnny has a spectacular aura about
My team used the 1/4 inch clear polyurethane tubing from mcmaster. I constructed a welder out of these parts listed:
Materials:
-one 6-inch piece of KOP C-Channel(cut out notches on each side where the holes are lined up so that the belt can be taken out once it is welded)
-squirt bottle WITH WATER!
-Heat gun
-pair of nice channel locks
-piece of flat bar(used for rolling the belting to create smooth weld)
Process:
1: cut an access whole on each side of the c-channel so that each end of the belting can touch and be pulled out with ease(when it is connected).
2:Have one person hold each side of the belting slightly spaced apart while another uses the heat gun to start a slight melt on each side of the belting(person holding the belts might need some gloves if you have sensitive hands )
3: As the belts start to look "melty", push them together and continue to heat to the point when the ends of the belt reach its melting point, then remove the heat.
4: Use channel locks to squeeze the belting smooth and squirt with water to cool it down so it can retain its shape.
5: Place belting on flat surface and roll it with the flatbar(works nicely if it's cold), I usually rolled in once forward, and once back.
6; Now, brag (graciously) about how successful a weld you have without spending 300-400$ on a belt welder
We were able to weld 30 belts in about 45 minutes(including a snack break). It might take a few tries to master, but the welds will turn out really nice, almost as if you bought a welder to do it for you.
anyheck anyheck is offline
FRC #2242 (Cougars)
anyheck is on a distinguished road
I have no experience with this material. Does its texture allow some slip on the balls, to avoid jamming them together when they are 'queued' in your conveyor systems.
We used rubber surgical tube and it had nothing but grip, so we had to keep the balls spaced out well to avoid jams.
I wanted to find a semi-slippery material to re-work the belt system just for the experience.
Unread 02-04-2009, 00:55
dtengineering's Avatar
AKA: Jason Brett
we found that the 1/4" hollow core worked quite nicely and could be asssembled in place. that might be my choice for quick fixes and retrofits.
Jason
my first post from a cell phone... isn't technology coool?
Unread 02-04-2009, 00:58
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
This stuff is excellent as semi-slip material. It isn't grippy like rubber surgical tubing, but the problem is that it may not pick up as quickly (in my experience-we put tread on our bottom rollers to aid pick up). You can pretty much jam balls down our hopper and then pull them out just as easily.
Going back to the welding discussion, 766 used the yellow hollow cord this year, and we just welded it together with a heat gun. We held the ends in the heat until they melted slightly and put them together when melted, waited for cooling and dremeled (with that sanding attachment) the surrounding blobs off. In two regionals we've never had any loop break.
Technology is cool!
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Unread 02-04-2009, 01:21
AdamHeard's Avatar
Lead Mentor
Originally Posted by Aren_Hill View Post
see also the god of polycord:
http://www.chiefdelphi.com/media/photos/33403
all welded i believe, i'll let Adam chime in on that
yeah...lol its good stuff
I just changed my usertitle thanks to your inspiriration Aren.
Well, pretty much; I don't see any reason not to do solid core. We bought our 1/4" for $0.60 a foot, just try to beat that with prewelded or the barbed kind.
In terms of welding, we just use a soldering gun with a flat tip, and initially used a jig that was thick aluminum plate with a 1/4" groove. We would've done all that way but found just the jig from the welding kit on ebay for $50. The jig made it easier to keep the waste material consistent, and made the process faster. With 74 belts per robot, and changing center to centers along with stretch several times, it added up.
Our process has always been this. Cut to the length we desire (we made an excel where we put in waste material, desired stretch, and pulley Center to center... it spits out what length to cut to) melt the ends nicely, squeeze together (same process for both plate and jig). We end up with a good deal of excess material around the weld, we initially trimmed it with dykes, but in a moment of laziness I found a belt sander with fine grit works GREAT.
I've strength tested every belt welded myself, the kids think it's because I'm fearless, I think it's because I'm stupid. So far, only ones with obviously poor welding have broken, and only 2-3 at that. As shown by Billfred, I tested HARD; usually by stepping on one end and pulling up with both arms.
Sooooo. In other words, we'd do the same thing in the future.
Unread 02-04-2009, 01:37
Matt Howard's Avatar
Matt Howard Matt Howard is offline
Submarine Sailor
FRC #1622 (Spyder)
Matt Howard has a spectacular aura aboutMatt Howard has a spectacular aura aboutMatt Howard has a spectacular aura about
Another material to keep in mind for belting this late in the game, is pneumatics tubing. We kit sized tubing, and connected it to itself with barbs. We haven't had a single failure, and if somehow we ever ran out of tubing, replacement tube wouldn't be hard to come by!
-2010 Las Vegas Regional Judges Award
-2010 Las Vegas Regional Safety Award
-2010 San Diego Regional GM Industrial Design Award
-2010 San Diego Regional Excellence in Design Award
Unread 02-04-2009, 01:38
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Yeah, pretty much what AdamHeard said, except for the spreadsheet.
2016 Central Illinois Winner. Curie Division finalist
Unread 02-04-2009, 07:14
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
For size, you shouldn't need anything thicker than 3/8, my team used 5/16 and it is proabably what I'd recommend. A hot plate is what I would recommend for attaching them. If you need to fix them while they are on the bot I'd use heat gun. Most people say let it cool off before you put tension on, this is very good advice. Try not to stretch before it is completely cooled down, probably about 1/2 an hour to an hour. If it's in the heat of competition, get some Dust Off, and spray the belt, it should decrease the cooling time exponentially. I'd use PVC pipe for the rollers. Get some Sched 80 2 or 3 inch Diameter, and cut about a 1/8 inch groove everywhere that you want the belt to go. Then I'd take a piece of PVC whose ID is the same as the original one's OD and put two thin pieces on either side of each groove to further prevent slipping.
Pneumatic Tubing Magnechu Pneumatics 6 28-01-2008 21:44
pneumatic tubing Matt21q General Forum 1 19-02-2007 20:05
Curley Tubing natis Pneumatics 5 20-01-2007 18:22
Tubing In Autodesk unapiedra Inventor 13 24-05-2005 11:59
Tubing pfortunejr Technical Discussion 6 11-01-2002 08:10
