Go to Post Mentor-built (adj.): A term describing a robot that is better than your own, and / or a robot with paint on it. - Chris is me [more]
Go Back   Chief Delphi > Competition > Regional Competitions
  #121   Spotlight this post!
Unread 30-03-2009, 13:27
CSideris28's Avatar
CSideris28 CSideris28 is offline
AKA: Christos Sideris
FRC #1155 (Sciborgs)
CSideris28 will become famous soon enough
Send a message via AIM to CSideris28
Re: Archiving Regionals Video 2009
Does anyone know when the rest of the Connecticut Regional footage will be available? Currently only the first day of matches is up on TBA.
2009 UTC Regional Champions!!! (Thanks 126 and 1902!!! Exploding Sciborg Force!!)
2009 NYC Regional Finalists (Thanks 2344 and 743!!!)
2009 NYC Regional Excellence in Automation and Control Award Winner
2007 NYC Regional Chairmans Award Winner
2007 NJ Regional Finalists (Thanks 359 and 486!!!)
  #122   Spotlight this post!
Unread 30-03-2009, 14:50
Originally Posted by Greg Marra View Post
Some parsed Las Vegas (NV) is on its way up to TBA right now. If you go to edit this, make sure not to duplicate effort
Are you referring to the semifinals and finals I uploaded already (and mentioned earlier in this thread), or did someone already start parsing the stuff I uploaded to firstvideoarchive?
Originally Posted by rtfgnow View Post
What programs do people use to convert .mp4 to .wmv for windows movie maker?
I used avidemux on linux. I'm not sure what people use on windows, but if possible, it would be best to keep it as mp4 and avoid transcoding to wmv.
  #123   Spotlight this post!
Unread 30-03-2009, 15:20
ATannahill ATannahill is offline
AKA: Alex Tannahill
Windows movie maker does not take mp4, could you point me in the direction of a free software that does take mp4?
- Arizona North
  #124   Spotlight this post!
Unread 30-03-2009, 15:53
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
I use a program called meGUI and two other pieces of software that expand it's video compatibility. Just a warning, it is not the most user friendly software out there.
AVIsynth and FFDShow allow meGUI to work with different types of media and should both be installed before meGUI.
After installing AVIsynth and ffdshow you can install meGUI.
The first time you run meGui you will need to create a worker under the Worker menu. I also recommend checking the "Autostart Queue" under Options->Settings.
My parsing procedure is to open the video using the meGUI File->Open. If the video is not directly compatible with meGUI this automatically opens a dialog to create an AVISynth script. I crop here if necessary and then save the script. You can also deinterlace during this step if necessary by setting the source type to Interlaced and checking the Deinterlace box on the "Filters" tab.
Next I open AVS Cutter from the Tools menu and select the newly created AVS file. Find the beginning of the desired clip in the window and click "Zone Start" find the end of the clip and click "Zone End", then click Set to set the zone. Repeat for the score if desired. After your desired cuts are set click "Do All and Close" in the non-video window.
I am not very familiar with encoder settings so mine might not be ideal, but I set the video to "x264: CE-Baseline". In the "Cuts" section of the audio select the .clt file that corresponds to the video you are editing. For Audio Encoder I use "Nero AAC: NDAAC - iPod - Good".
Click AutoEncode and set the Average Bitrate to 1000kbits/s.
Then rinse and repeat.
  #125   Spotlight this post!
Unread 31-03-2009, 11:32
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Originally Posted by Mike AA View Post
Just upload them to TBA they will get copied over to FVA (firstvideoarchive) which is now what soap points to.
Mike AA
Everything's been uploaded, feel free to copy it - especially since TBA doesn't link to awards and such, and many teams like to have copies of it.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
  #126   Spotlight this post!
Unread 31-03-2009, 12:48
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'm the weak link in the Peachtree/Lonestar video chain. I've been unexpectedly busy at work, and this week I'll be packing up house for a big move saturday. I should be able to get to things early next week.
I don't think uploading my unparsed video is quite as practical as for some people, as it's stupid high quality so I can do a decent job deinterlacing it and still have something useful to compress down to the TBA format and a set of larger MPGs for teams to use for their own purposes.
  #127   Spotlight this post!
Unread 31-03-2009, 14:27
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
Wisconsin has been digitized and will be sent around for parsing this evening. I'm hoping to get all files uploaded by the end of the weekend.
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
  #128   Spotlight this post!
Unread 02-04-2009, 20:26
bobwrit's Avatar
bobwrit bobwrit is offline
//No Comment
AKA: ...
FRC #1977 (Loveland High Robotics)
bobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nice
Apparently, Colorado School of Mines has an archive of Colorado somewhere, but I can't find it. I'll continue searching, but it is there.
FRC Team 1977 Alumni
Has Attended:2008 Colorado regional
2009 Colorado Kickoff
2009 Colorado Regional
2010 Colorado Kickoff
2010 Colorado Regional
The most exciting phrase to hear in science, the one that heralds new discoveries, is not "Eureka!"(I found it!), but rather, "Hmm.... That's funny" ---Isaac Asimov
Chance favors the prepared mind ---Louis Pasteur
And you can tell me, that I can't make a diffrence because I'm just one, but one is all it takes to start it. And you can tell me, that I can't change the world because I'm too young, but I wont stand here and be your target. ---FM Static
  #129   Spotlight this post!
Unread 03-04-2009, 12:04
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
I appreciate Team 48 for archiving and streaming the regional, but I pray that next season, they don't use FLV. It's a huge hassle. I've yet to find a good program (commercial or free) that can successfully convert the files. Had it been another standard, Buckeye would be up by now.
Anyway, I'm probably just going to upload them somewhere soon.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
  #130   Spotlight this post!
Unread 03-04-2009, 22:16
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I am at a regional this weekend and I have midterms all next week, but after that I may be able to convert these for you. I tested the method I use on an FLV and it appeared to work.
  #131   Spotlight this post!
Unread 03-04-2009, 23:30
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
I have NJ Day 2 and All days for Finger Lakes
downside is it's a huge *** file so to get it out to the central archiving area will be a hassle =P
I use My Video Converter for Windows
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
  #132   Spotlight this post!
Unread 04-04-2009, 00:01
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
does anyone want to help with waterloo and GTA regionals? I doubt il have the time before championships and i know people are waiting for them to go online...
  #133   Spotlight this post!
Unread 04-04-2009, 00:15
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
How huge is huge? 2GB?
  #134   Spotlight this post!
Unread 04-04-2009, 00:41
mtaman02's Avatar
umm big lets leave it at that lol...
Now I know why they came out with Terabyte drives
I didn't have time to scale back the quality since I was busy doing WPA / Spare Parts and Field Related work.
NJ (Sat) 15.6GB WMV Format
ROC (Thu, Fri & Sat) 30GB Total WMV Format
If you can scale back the quality you'll def. get a smaller file size but I'm hardly home to really "sit" with it or to just set it and forget it.
Volunteer Resume:
  #135   Spotlight this post!
Unread 04-04-2009, 12:55
synth3tk's Avatar
AKA: David Thomas
I've been running FTP uploads and torrents at nights recently. I'll probably do these tonight.
2009 Minnesota Regionals AndyB Regional Competitions 48 06-01-2009 11:31
Archiving Recorded Regionals 2008 Jonathan Norris Scouting 155 24-09-2008 10:25
2009 FTC Regionals JoeyMee VEX 5 29-04-2008 22:26
Coordinated Regional Video Archiving.. Joel J Scouting 260 01-10-2007 22:45
