Go to Post -Our engineering mentor, Mr. Wittel- *crossing arms and sitting down* "Ahhh. I love work. I could watch it all day." - OverdriveAdge [more]
Unread 02-04-2009, 15:18
Tank2010's Avatar
Tank2010 Tank2010 is offline
Draftsman. Ammoknights Rule!
AKA: Dave
FRC #1566 (Ammoknights)
Tank2010 is an unknown quantity at this point
Air compressor
How much PSI can the air compressor put into clippard tanks?
Team 1566 Rules!!!!!!!!
Unread 02-04-2009, 15:22
Re: Air compressor
No more than 120 PSI. This is due primarily to <R01-B> and the required automatic vent valve.
Unread 02-04-2009, 15:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Air compressor
Read the robot rules and the pneumatics manual
http://usfirst.org/community/frc/content.aspx?id=452
you should find that it's allowed to put 120 psi into the tanks, but typically will only put about 115 psi because of how the pressure switch is calibrated. And that you can only use 60 psi...
Unread 02-04-2009, 18:56
Re: Air compressor
<R01> Energy used by FIRST Robotics Competition ROBOTS, (i.e., stored at the start of a
MATCH), shall come only from the following sources:
B. Compressed air stored in the pneumatic system, stored at a maximum pressure of 120 PSI
in no more than four Clippard Instruments tanks. Extraneous lengths of pneumatic tubing
shall not be used to increase the storage capacity of the air storage system.
<R75> “Working” air pressure on the ROBOT must be no greater than 60psi. All working air must
be provided through one primary Norgen adjustable pressure regulator.
A. All “working” pneumatic components (e.g. valves, cylinders, rotary actuators, etc.) must
be downstream from this regulator.
B. Only the compressor, relief valve, pressure switch, pressure vent valve, pressure gauge,
storage tanks, tubing, and connecting fittings may be in the high-pressure pneumatic
circuit upstream from the regulator.
C. Pressure gauges must be placed in easily visible locations upstream and downstream of
the regulator to display the “stored” and “working” pressures.
D. If the compressor is not included on the ROBOT (under the provisions of Rule <R74>),
the regulator may be located on-board or off-board, provided all other pneumatic rules
are satisfied. Note that if the regulator is kept off-board the ROBOT with the
compressor, then only low-pressure (60psi or less) “working” air can be stored on the
ROBOT.
<R76> The relief valve must be attached directly to the compressor. Teams are not allowed to
adjust the 125-psi relief valve. The valve has been calibrated prior to shipping.
<R77> The Nason pressure switch must be connected to the high-pressure side of the pneumatic
circuit (i.e. prior to the pressure regulator) to sense the “stored” pressure of the circuit. The
two wires from the pressure switch must be connected directly to a digital input and ground
port on the Digital Sidecar, and the cRIO Mobile Device Controller must be programmed to
sense the state of the switch and operate the relay module that powers the compressor to
prevent over-pressuring the system.
Unread 02-04-2009, 20:25
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Re: Air compressor
Just out of curiosity, does anyone know what the compressor itself is rated for?
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 02-04-2009, 20:30
MrForbes's Avatar
AKA: Jim
Re: Air compressor
doh......100 psi
http://www.drillspot.com/products/35..._Va cuum_Pump
(the "doh" is NOT directed at you, Mr. Freeman!)
Unread 02-04-2009, 21:19
AKA: Kellan
Re: Air compressor
How does one go about using that compressor as a vacuum pump? I didn't think that it was capable of that, but it's listed as "Compressor/vacuum pump"
-Douglas Adams
-Theodore Gray
Unread 02-04-2009, 21:28
MrForbes's Avatar
AKA: Jim
Re: Air compressor
wild guess: reverse the polarity of the power wires?
Unread 02-04-2009, 21:47
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Air compressor
I vote to let someone else try that and report the results back to us.
Unread 02-04-2009, 21:50
MrForbes's Avatar
AKA: Jim
Re: Air compressor
it's probably a reed valve compressor, and motor direction has nothign to do with airflow
Unread 02-04-2009, 22:30
Re: Air compressor
The compressor does work wired both ways, but not very well.
Unread 03-04-2009, 01:59
AKA: Kellan
Re: Air compressor
I think there was a thread on here awhile back about the compressor compressing regardless of polarity but something about cooling fans spinning backwards and not working well if it was plugged in backwards. I can't seem to find a manual anywhere or instructions about turning this into a vacuum pump.
-Douglas Adams
-Theodore Gray
Unread 03-04-2009, 02:03
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Air compressor
Ok, I think I got this one. We tried to use an "Add on" That allowed us to reverse it to use Suction. We tried this in 2007 and it did not work. The part kinda looked like a solenoid and I found it while looking for something else. I hate posting vaguely. But if I find the real thing I'll post it here.
R.C.
MadTown Robotics Team 1323
Unread 03-04-2009, 02:23
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
Re: Air compressor
I believe you're referring to a Venturi vacuum pump, which would work with any pressure line. The compressor itself may actually be able to function as a vacuum pump on its own. I'm not sure how though.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 03-04-2009, 07:55
Re: Air compressor
This compressor is known as a "wobble" or WOB-L (TM) pump. The piston is a single piece integrated with the piston rod and seals. It does not have a wrist pin where the rod connects to the piston. This model is not designed for vacuum so you must use a venturi to produce vacuum using this pump. Thomas does make another pump that looks similar that does produce vacuum. It essentially is the same pump with a different head and valve assembly. That pump is part of the 415 series not the 405 series.
The pump works fine in either direction, but the efficiency is higher in the direction marked and therefore less heat is developed.
Automated Air Compressor code ShotgunNinja Programming 12 14-02-2008 15:52
AIR COMPRESSOR !!! edgar_amaro Pneumatics 11 05-02-2008 00:43
Air Compressor Question Jrocklz Pneumatics 4 17-01-2008 21:36
Off robot air compressor sanddrag Rules/Strategy 52 11-01-2007 15:11
Air Compressor geo Technical Discussion 4 06-02-2002 22:52
