Go to Post "FIRST" is not a verb (yet - give us time, and we will see what happens). - dlavery [more]
Unread 03-04-2009, 01:21
Matt Howard's Avatar
Matt Howard Matt Howard is offline
Submarine Sailor
FRC #1622 (Spyder)
Matt Howard has a spectacular aura aboutMatt Howard has a spectacular aura aboutMatt Howard has a spectacular aura about
Re: Pneumatic Tubing
Originally Posted by Daniel_LaFleur View Post
If you are going to use it for pneumatics, the answer is NO. You will severely degrade the operating and burst pressure of the tube.
If you plan on using it for belting material, then yes it will work ... but the degraded strength of the joint may fail (IE when you melt polyurethane tubing it gets weaker but will bond together)
You cannot use heat to "weld" the pneumatic tubing, as the tubing actually expands with heat. But yes, we used barb fittings. The connection created is so strong, that another mentor and I pulled as hard as we could on a link we made, then gave had a student pull as well and only after about 2 minutes of straining we finally got it to pop open.
The joints created by the barbs are very strong.
-2010 Las Vegas Regional Judges Award
-2010 Las Vegas Regional Safety Award
-2010 San Diego Regional GM Industrial Design Award
-2010 San Diego Regional Excellence in Design Award
Pneumatic Tubing Magnechu Pneumatics 6 28-01-2008 21:44
pneumatic tubing Matt21q General Forum 1 19-02-2007 20:05
Using other pneumatic tubing Crtcalmss Pneumatics 3 18-01-2007 09:16
problems with pneumatic tubing in telescoping arm johnnymac4545 Pneumatics 5 25-02-2005 11:19
Pneumatic Tubing Question Ryan Dognaux Pneumatics 2 31-01-2004 20:23
