Go to Post We also indirectly benefit from those rookie teams having well-built and working drivebases. It helps raise the level of performance across the board, making for a better competitive environment. - Alan Anderson [more]
Unread 02-04-2009, 14:24
kapolavery's Avatar
kapolavery kapolavery is offline
All Your Base Are Belong to FIRST
AKA: Avery-John Domingo
FRC #2445 (RoboKAP)
kapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to behold
Pneumatic Tubing
so i read the whole part about melting the polycord together with a lighter
and i was wondering whether it would work the same using pneumatic tubing
thanks!
"There's always next year..."
Unread 02-04-2009, 16:08
Anders Horn Anders Horn is offline
FRC #2557
Anders Horn is an unknown quantity at this point
Re: Pneumatic Tubing
I do not think so, try testing.
Unread 02-04-2009, 16:39
AdamHeard's Avatar
Lead Mentor
I know 1622 used pneumatic tubing as their belts, I suspect they connected with barbs that were inserted that hold the ends together, but may be wrong.
I'd send them a message.
Unread 02-04-2009, 16:41
kapolavery's Avatar
FRC #2445 (RoboKAP)
how can i get a hold them?
Unread 02-04-2009, 17:28
I can think of a couple of ways...
1) Go to the FIRST website. 1622 is based in Poway, CA and attended San Diego and Las Vegas. Searching through the map icon or going through the regional list will get you a team info page, with a link to their site. If they don't have contact info there, I will be extremely surprised.
2) Go to the CD member list and do an advanced search for team number 1622. With a little bit of care, you should be able to find the more active CD members and get a message to them.
Unread 02-04-2009, 21:12
POWSpyder's Avatar
POWSpyder POWSpyder is offline
Chris1622
AKA: Chris Holliday
FRC #1622 (Team Spyder)
POWSpyder is an unknown quantity at this point
Yea we used barb fitting to connect our pneumatic tubing together for our conveyor, and they work great. I would recommend using this system over the poly cord because it is very easy to change/shorten if needed.
"Seek and Destroy" that says everything about the robot.
Unread 02-04-2009, 21:34
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
thanks!
If you are going to use it for pneumatics, the answer is NO. You will severely degrade the operating and burst pressure of the tube.
If you plan on using it for belting material, then yes it will work ... but the degraded strength of the joint may fail (IE when you melt polyurethane tubing it gets weaker but will bond together)
___________________
- Tennyson, Ulysses
Unread 03-04-2009, 01:21
Matt Howard's Avatar
Matt Howard Matt Howard is offline
Submarine Sailor
FRC #1622 (Spyder)
Matt Howard has a spectacular aura aboutMatt Howard has a spectacular aura aboutMatt Howard has a spectacular aura about
You cannot use heat to "weld" the pneumatic tubing, as the tubing actually expands with heat. But yes, we used barb fittings. The connection created is so strong, that another mentor and I pulled as hard as we could on a link we made, then gave had a student pull as well and only after about 2 minutes of straining we finally got it to pop open.
The joints created by the barbs are very strong.
-2010 Las Vegas Regional Judges Award
-2010 Las Vegas Regional Safety Award
-2010 San Diego Regional GM Industrial Design Award
-2010 San Diego Regional Excellence in Design Award
Unread 03-04-2009, 01:23
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
3) wait a little while and they'll answer themselves
Unread 03-04-2009, 02:44
kapolavery's Avatar
FRC #2445 (RoboKAP)
is it available say like at home depot or something that id have to order..
should i try plastic fittings or brass/metal fittings
and what size?
is this how they look like?
Unread 03-04-2009, 03:02
kapolavery's Avatar
FRC #2445 (RoboKAP)
and btw
this is just for our side project.. being that our season is over..
our teacher wants us to build a robot with a "ball pick up" mechanism.
and improving our bot is what my grade depends on ahah
so itll be a fun last senior project
thanks guys for helping out!
Unread 03-04-2009, 04:13
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
and what size?
That's what a barbed fitting at Home Depot would look like if you were going to use the tubing to carry water or some other liquid. To get the barbs for making conveyor type belts, try someplace like McMaster:
http://www.mcmaster.com/#6567k22/=1a4azx or
http://www.mcmaster.com/#6567k65/=1a4b43
Art Dutra IV
世上无难事,只怕有心人.
Unread 03-04-2009, 04:17
kapolavery's Avatar
FRC #2445 (RoboKAP)
ok that helps..
but is it something that i have to order?
shipping stuff to hawaii takes a long time..
or is there a way to improvise using maybe.. short bolts..washers..glue even?
after all its not for competition but for my school project hehe
so just as long as the concept will work its fine.
Unread 03-04-2009, 06:51
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Considering that I've heated polyurethane tubing to the point where it will bond with itself ... I'd say that you are incorrect here. I also agree with you that barbs are the way to go, for reasons I stated in my earlier post
ok that helps..
If you want to experimant a bit:
Take a small piece of threadded rod (with the OD of the rod slightly larger than the ID of the tubing). Heat the tubing to get it soft enough to push over the ends of the rod. This should work, depending on the load you put on it. I'd also suggest you push the tubing so that the 2 ends meet in the center of the rod.
___________________
- Tennyson, Ulysses
Unread 03-04-2009, 12:20
Submarine Sailor
FRC #1622 (Spyder)
We're going to have to agree to disagree on that point then, because when we did it the tube expanded and was unusable.
ok that helps..
The barbs we used were from McMaster, and are brass. I cannot for the life of me remember the part # but I can find out for you.
Before we were using the barbs, to test the lift system we took #8's, cut the heads off and left about .5 inch, then pressed the ends of the tubes onto the remaining bit. We had pre-drilled the tubes about .70 inches away from where the #8 would be housed within the tube, and used small cable ties through the tubing to cinch it together.
It worked, but was really only a temporary solution in our eyes.
Pneumatic Tubing Magnechu Pneumatics 6 28-01-2008 21:44
pneumatic tubing Matt21q General Forum 1 19-02-2007 20:05
Using other pneumatic tubing Crtcalmss Pneumatics 3 18-01-2007 09:16
problems with pneumatic tubing in telescoping arm johnnymac4545 Pneumatics 5 25-02-2005 11:19
Pneumatic Tubing Question Ryan Dognaux Pneumatics 2 31-01-2004 20:23
