Offseason rc project
I am looking for a few suggestions.
What should I use to get some video feedback? Also, does anyone know of an RC contoller, that can control 4 motors independently? |
Re: Offseason rc project
It would help if you'd give us a better idea of what you're trying to do.
There are 2.4ghz wireless "baby monitor" video systems you can buy at retail stores. The vex transmitter/reciever and signal splitter is a low cost way to get independent control of 4 motors, although you need to add 4 speed controllers (banebots sells some of different current ratings). If you just need small motors you could use vex motors (they are essentially a servo with no stop) |
I didn't know about that, thanks for the link!
Also, it depends on what you want to do. I THINK that the 2.4gHz stuff is allowed to control airborne vehicles but if you go with a cheaper non-digital transmitter you may have to check the frequencies so as not to run afoul of the FCC.
Also, Im not sure how the VEX controller works but I dont think it has a failsafe on each channel. If you are doing anything large you will probably WANT some sort of failsafe in place. Camera wise a quick bit of googling showed up http://www.sparkfun.com/commerce/pro...oducts_id=9189 as an option. Here are some 4 channel receivers http://www.robotmarketplace.com/prod...4_channel.html Here is a 6 channel digital one http://www.robotmarketplace.com/prod...-SPM66001.html Just ideas of places to look. Hope this helps. |
| saving project as a new project | windell747 | NI LabVIEW | 3 | 01-02-2009 04:41 |
| 171 Offseason Project | AndyB | Robot Showcase | 2 | 08-09-2008 13:41 |
| pic: 2273's offseason project(Skills Canada) | Binome | Extra Discussion | 0 | 20-04-2008 21:21 |
| pic: Offseason Project Teaser | ZZII 527 | Extra Discussion | 12 | 19-07-2007 20:07 |
| Offseason gearbox project... maybe this gearbox has helical gears? | Travis Covington | Technical Discussion | 17 | 05-06-2006 11:48 |
