Go to Post Every event that starts with "a little bit of fun" has the potential to end in disaster. Please think about all possible outcomes before you do anything stupid. - sanddrag [more]
Unread 03-04-2009, 09:39
dboisvert dboisvert is offline
AKA: Dan Boisvert
FRC #2405 (Divided by Zero)
dboisvert is an unknown quantity at this point
Offseason rc project
I am looking for a few suggestions.
What should I use to get some video feedback?
Also, does anyone know of an RC contoller, that can control 4 motors independently?
Unread 03-04-2009, 11:43
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Offseason rc project
It would help if you'd give us a better idea of what you're trying to do.
There are 2.4ghz wireless "baby monitor" video systems you can buy at retail stores.
The vex transmitter/reciever and signal splitter is a low cost way to get independent control of 4 motors, although you need to add 4 speed controllers (banebots sells some of different current ratings). If you just need small motors you could use vex motors (they are essentially a servo with no stop)
Unread 03-04-2009, 11:48
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
This is what came to mind for me too. You could even use the Vex camera kit while you're at it.
FRC 766, 2015-, Mentor
Unread 03-04-2009, 12:01
MrForbes's Avatar
AKA: Jim
I didn't know about that, thanks for the link!
Unread 03-04-2009, 12:46
Joining the 900 Meme Team
FRC #0079
Also, it depends on what you want to do. I THINK that the 2.4gHz stuff is allowed to control airborne vehicles but if you go with a cheaper non-digital transmitter you may have to check the frequencies so as not to run afoul of the FCC.
Also, Im not sure how the VEX controller works but I dont think it has a failsafe on each channel. If you are doing anything large you will probably WANT some sort of failsafe in place.
Camera wise a quick bit of googling showed up http://www.sparkfun.com/commerce/pro...oducts_id=9189 as an option.
Here are some 4 channel receivers http://www.robotmarketplace.com/prod...4_channel.html
Here is a 6 channel digital one
http://www.robotmarketplace.com/prod...-SPM66001.html
Just ideas of places to look. Hope this helps.
saving project as a new project windell747 NI LabVIEW 3 01-02-2009 04:41
171 Offseason Project AndyB Robot Showcase 2 08-09-2008 13:41
pic: 2273's offseason project(Skills Canada) Binome Extra Discussion 0 20-04-2008 21:21
pic: Offseason Project Teaser ZZII 527 Extra Discussion 12 19-07-2007 20:07
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
