Go to Post So perhaps those that are so eager to complain might realize that if they spent a little less time complaining and a little more time analyzing the problem and developing solutions, then they might have a little less to complain about. - dlavery [more]
Unread 01-04-2009, 20:44
Billfred's Avatar
Billfred Billfred is offline
Re: What do you think of the jaguars?
To my knowledge, neither 1618 nor 2815 burned out any Jaguars this season. (1618 used four on their robot, 2815 used four Jaguars on their manipulator and two Victors on the drivetrain.)
They're still a little big for my liking, but I'm intrigued by their potential.
Unread 01-04-2009, 22:53
roboraven15's Avatar
roboraven15 roboraven15 is offline
FRC #1188 (Oaktown Crewz)
roboraven15 is an unknown quantity at this point
Send a message via AIM to roboraven15
what we have noticed, jaguars burn up before the motors do (in a situation of overstressing motors), which is pretty handy honestly rather change jag than motor.
Unread 01-04-2009, 23:34
AKA: Dr. Brooks
no team (WRRF)
To add two cents worth, we switched from Victors to Jaguars
on our drive in order to enable reliable operation of current sensed
traction control. The 120 hz chop rate of the victors was too low
to be smoothed out adequately with an RC fiter we put on the
current sensor. We did note that we lost a little top end speed
with this change, but the resulting traction control was worth
the trade.
The 40 amp current limit on the Jaguars was pretty aggressive
and we did hit that limit during testing with a gearbox that was
binding a bit. We did not have any Jaguars fail.
Eugene
Unread 02-04-2009, 07:57
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
We use two Jags. One for each side of the drive-train. Everywhere else we are using victors. We have had no failures of either the Jags or the Victors on either our comp bot or practice bot. I will say this, we mount all of our speed controllers vertically above our drive motors. This ensures the minimal amount of particulate to fall into the enclosure of the Jag. One key difference between the Jag and the Victor, the Jag does not have a conformal coating, the Victor does. I believe that this is a contributing factor to the number of failures seen.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 02-04-2009, 08:32
Jared Russell's Avatar
Taking a year (mostly) off
We also mounted our Jags vertically, and have yet to lose a single one on either our main machine or our practice bot. I think that since particulate seems to be one of the single biggest factors in the failure of the Jags thus far, vertical mounting is (at the moment) the way to go.
Unread 02-04-2009, 09:04
Gdeaver Gdeaver is offline
FRC #1640
The higher frequency PWM drive of the Jags means they also will have higher switching losses. This means more heat to dispose of compared to a victor. The victors used IFR or Infineon FETS. Could the IFR FETS have better avalanche carrying ability? I Know that Luminary Micros has aligned with Fairchild but, could the IFR FETS be a better device for this application. Our robots are 12 volt devices cars are 12 volt nominal devices. Why not use automotive qualified and avalanche rated FETS ? Automotive motor controllers all seam to use 40 volt devices and our controllers are using 30 volt FETS. Does the jag have clamping diodes to take the Back EMF stress off of the FET intrinsic diode? Most hard switched motor controllers do. With the current loads we give the JAGS cooling is critical. Could the air flow not be evenly distributed across all the Fets? With the higher frequency PWM drive, there is more of a problem with ringing in the gate drive circuitry. Could this be causing the Fet and drive chip failure? The Jag is a step forward with capabilities we haven't even tapped yet, however there does SEAM to be an increased failure rate that needs to be addressed. Every year there will be a number of reverse polarity failures no matter which controller we use. This is just a given unless reverse battery protection is implemented.
Unread 02-04-2009, 11:59
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
We at first used 3 Jaguars on our robot, 2 on the drive and one in steering. I liked the larger response range and slower speeds capable of the Jaguars. After 2 regionals and 24? matches we have not had any problems and I will likely ask for more for next year. We primarily used them on the drive and steering for the more "detailed" capability. Our shooter and rock elevators didn't need precision and to save weight we used victors.
-Mike AA
Unread 02-04-2009, 15:00
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
I'd rather burn up a $28 CIM motor than a $75 speed controller. I think the other motors are also significantly cheaper than the Jaguar.
I suppose the only case where you might prefer to replace the speed controller is if you're pressed for time (eg between matches) and the speed controller is easier to access than the motor. In general though, I'd rather have a cheaper part fail than a more expensive part.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 02-04-2009, 15:25
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
We used 7 Jaguars and 1 Victor on our robot and 2 on our test robot back at the shop. The Jaguars went into Fault mode once, not resulting in failure, before we shipped the robot, but I think it was caused by a low battery. No Jaguars were lost on our team. From our team's standpoint, I think we like the Jaguars and are very eagerly awaiting news on the CAN bus and the other features on the Jaguar.
Unread 03-04-2009, 08:04
current sensor.
Eugene
Doc,
What were you using for a current sensor? The KOP supplied or something else.
Unread 03-04-2009, 09:08
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
We do the exact same thing ! The Jags are the best for drive related functions.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 03-04-2009, 11:53
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We haven't had any trouble with the Jaguars. We have four of them, driving all the motors that need precise speed control, plus a few Victors driving the rest of the motors. Ours are mounted vertically in a covered wooden box that opens away from the rest of the robot, so it would be very difficult for stray particles to get into them. also none of our motors are heavily loaded, by design.
LM (and IFI for that matter) could do a much better job of marking the terminals, it would not take too much effort for them to put big, legible warning lables stating which side goes to the motor, and which to the battery, and warning about polarity. This could save teams a lot of heartache...we all know that everyone should know how to wire things properly, but reality is that a lot of people who work on the robots are still learning about electricity, and taking extra steps to reduce expensive mistakes is warranted.
Unread 03-04-2009, 12:03
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
I hate to say this and I don't wanna sound mean but if you have new kids doing robot related work that can easily get messed up by just having the wires reversed then it should be the job of the Alumni, Mentors, Coaches and other sources to instruct the kids during build season how how things should properly be wired AND supv. them as they're doing it to ensure it's done right. Don't just tell them how to do it and walk away or leave it to them to research it... While self teaching is good, doing it during build season is not the time for that to happen. Each committee should be well trained before build season in what they have to do to have a successful team showing.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 03-04-2009, 12:08
A small but easily-seen stripe from an appropriate-colored sharpie has been marked on the plastic next to each terminal on ours.
Using colored screws is a half-baked solution. They come out. It only takes a small error in putting them in to practically ensure that the next person to try to follow the color code will introduce a wiring fault that can destroy the part.
Unread 03-04-2009, 12:09
MrForbes's Avatar
AKA: Jim
That is a great answer for those teams that have knowlegable mentors, coaches, and alumni. There are many young teams who don't have anyone who knows this stuff well, why not make things a bit easier for them?
What do you think is the best way to pick up the ball? Jamin008 Technical Discussion 5 14-01-2008 20:47
So what do you think of the new game? slickguy2007 General Forum 49 18-01-2005 11:30
What do you think of the EDUbot? team222badbrad Robotics Education and Curriculum 11 31-01-2003 18:46
What did you think of the Kickoff? Bduggan04 General Forum 6 04-01-2003 22:07
What do you think of the new game? Anand Atreya General Forum 7 06-01-2002 13:23
