Go to Post If you have a problem with a team, go to that team and address it with them. Don't air your slanderous opinions here for all to see. - Andy Baker [more]
Unread 03-04-2009, 13:00
uid60001 uid60001 is offline
FRC #3017
uid60001 is an unknown quantity at this point
Gearbox/reduction for CIM,RS550,RS540
We have some CIM, and RS540/550 motors left over from 2008 and 2009 kits. Interested to use them as future drive motor in the prototype platform. Normally, folks will use some gearbox to reduce the RPM of the motor to make it usable as drive motor. Have any one/team use either chain/sprocket or timing bell/pulley directly to drive the robot successfully. If yes, how and what are combination of sprocket/pulley parts numbers?
Dean
Unread 03-04-2009, 13:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Gearbox/reduction for CIM,RS550,RS540
Typical gearbox ratios are around 10:1 to 16:1 for the CIM, and three times that for the smaller motors. You would need multiple stages of reduction, and the one connected directly to the motors will turn very fast! Gears work better...that's why we use them....
Unread 03-04-2009, 13:36
kapolavery's Avatar
kapolavery kapolavery is offline
All Your Base Are Belong to FIRST
AKA: Avery-John Domingo
FRC #2445 (RoboKAP)
kapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to behold
k well if i understood what my teachers were tryna teach on gears..
the reason why you use the gear box is for mor torque.. right?
and more torque essentially means more power
whereas if you didnt have the gear box, youd have the high speed of the motor, but no power..
is it possible to not use a gear box (for weight restraints) and still create a good amount of gear reduction?
"There's always next year..."
Unread 03-04-2009, 13:53
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
The guys up the road from us on 612 didn't actually use transmissions for their drive system this year, check them out in Atlanta if you get the chance. They simply used a small pulley on each CIM and a large pulley (almost the same diameter as the lunacy wheels) bolted directly to the corresponding lunacy wheel.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 03-04-2009, 13:54
MrForbes's Avatar
AKA: Jim
Power stays the same, since power is torque times speed. You need gear (or belt or chain) reduction to reduce the speed, as well as to increase torque.
The first step is to figure out how fast you want the wheels to turn. A typical top speed for a robot is about ten feet per second. With eight inch wheels, which have a two foot circumference, you'd need the wheels to turn five turns per second (or 5 x 60 = 300 revolutions per minute) at full motor speed. Full speed of the CIM is about 5000 rpm, so you need a reduction of 5000/300 = 16.6:1
Look at the belts and pulleys you have, as well as the chains and sprockets. Figure out how many teeth are on the smallest ones, and how many are on the biggest ones, for each type of belt or chain. Divide the smallest by the largest, to get the maximum reduction for that type of drive system. For example, if you have a 36 tooth sprocket and a 15 tooth sprocket, you can get 30/15 = 2:1 recuction. If you have a 16 tooth pulley and a 56 tooth pulley, you can get 56/16 = 3.5:1 reduction.
You could connect a belt drive reduction directly to the motor, then add a chain reduction, and you multiply the ratios to get the total reduction. So if you used a 3.5:1 belt reduction, then a 2:1 chain reduction you would get 7:1 total reduction. Adding another 2:1 chain reduction would get it to 14:1 which would probably work pretty well. It will be a big, bulky drive, but it could work. Or buy some more sprockets, such as a 9 tooth and a 36 tooth, and you could get a 4:1 chain reduction.
Joining the 900 Meme Team
FRC #0079
It is possible to not use a gear box and create a good amount of torque. A gear box is just a means to an end, you can create a reduction through various means. These include gears, sprockets and chains, belts as well as less traditional means.
I recommend http://science.howstuffworks.com/gear.htm as a good introduction to the concepts and types of gears if you are interested.
Unread 03-04-2009, 16:12
FRC #3017
Thanks for all the input so far.
It looks like someone did it this year. From paper and commercial available part list, it is quiet easy to achieve 6:1~9:1 reduction with sprockets and timing belt pulley setup. The 6:1 is easily done at CIM's RPM. What worry me is the 12+K loaded RPM. Will the chain jump the sprocket or the belt jump the pulley at that speed under relative heavy load. Interested to hear from someone who tried the setup, whether it is success or failure.
Dean
Unread 03-04-2009, 21:53
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Here's another plug for JVN's design calculator. Team 234 used this tool to design their entire robot this year. I cannot push this tool enough...
http://www.chiefdelphi.com/media/papers/2059
Collin Fultz
Unread 03-04-2009, 22:01
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
I agree, this is a very handy tool and it rocks. BTW, 234 has a very smexy bot this year!
R.C.
MadTown Robotics Team 1323
pic: VEX High Reduction Gearbox JVN Extra Discussion 40 06-07-2009 16:58
CIM Reduction? excel2474 Technical Discussion 8 22-03-2009 23:08
CIM motor gearbox tseres Motors 3 22-05-2007 22:31
pic: Bike Cim + 56 mm gearbox NK2007 Extra Discussion 7 15-01-2007 01:10
Drill Motor Gearbox Reduction Ratios archiver 2000 3 23-06-2002 23:05
