Go to Post Minnesota could pioneer the idea of suspending a field 20 feet above the other field and have true double decker events. - PayneTrain [more]
Unread 04-04-2009, 21:11
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Set Digital out
I'm not a programmer, and so this may not be at all helpful, but I speak Binary.
Let's say you have bits one through eight and you want to set them.
Setting Bit 1 looks like this: 00000001
Setting bit 8 looks like this: 10000000
Setting both looks like this: 10000001
The first number is 1 (01h), the second number is 128 (80h), the 3rd number is 129 (81h).
So, if bit 8 is set on and all the rest are off, you're sending 80h. To turn Bit 1 on without affecting bit 8, send 81h.
As another example (work this out on paper) Bits 1, 5 and 8 on = 91h, and 1 and 5 only is 11h. Get it?
EDIT: I see it uses a binary number like 10000001, so convert the hexadecimal values in my example above to binary.
Sorting out Digital NASA TV Billfred General Forum 2 03-12-2007 18:55
pulsing digital out pins, not as fast as pwms Generalx5 Programming 5 02-04-2007 18:52
Digital out signal speed on off, almost like PWM but at max 60Hz Generalx5 Electrical 2 27-03-2007 12:26
Set Default Digital inputs to Low? How? bad Analog value? Generalx5 Programming 11 04-01-2007 18:57
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
