Go to Post Great teams with great software have control loops. Clever teams without software have pneumatics. - Chris is me [more]
Unread 05-04-2009, 14:13
dpeterson3 dpeterson3 is offline
FRC #1178 (DURT)
dpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the rough
Battery PSU
I want to run an old CPU mainboard off of a battery. I have been wanting to build an autonomous submarine for years. Last summer, I actually got a start on it, but never got to finish. I was going to use a Basic Stamp 2, but it just does not have a lot of the capabilities I want such as camera interface, processing power, or support for several sensors and still get some power out of it. I thought a CRIO would be perfect for what I want, but as you all know, they are very expensive. I looked around on Ebay for one, but could not find eny. However, I found quite a few old IO cards, relay cards, etc. cheap. I also have quite a few old mainboards lying around (people dump their old computers on me). I could easily turn one into a robot controller by using something like a Puppy linux distro on a flash drive. The problem I run into is power supply. I need to run the board off a battery. I have batteries that can handle the power draw, but I have no supply. I was thinking several voltage regulators would do it, but the ones I have (from Radioshack) only handle 1 Amp a piece. Can I put them in parallel to get more amps out of them or is there some better way to do this? Any ideas?
Unread 05-04-2009, 14:36
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Battery PSU
Something like this? http://www.powerstream.com/mini-itx.htm
If you already have a small 120V PSU lying around, you could get a small and cheap power inverter to step up the voltage, however, the efficiency will suck.
I also believe it is fine to parallel voltage regulators. Don't quote me on this though, but I believe this is how they do it in regular power supplies, but they may also put diodes on the output.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 05-04-2009, 14:37
jcatt's Avatar
jcatt jcatt is offline
AKA: Jonathan Catt
FRC #1902 (Exploading Bacon and FRC #1251 TechTigers)
jcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of light
Re: Battery PSU
You might want to concider buying a power supply for a "Car Computer", they are designed to power a motherboard and hardrive from an unregulated 12v input. Here is just one company I found while doing a simple Google search.
http://www.mpegbox.net/products.html
There are many company's offering PSU's like this but this is has the highest wattage from my searching.
Jonathan Catt
Co-Owner and Systems Architect of ColorScene Inc.
Co-Sponsor of The RoboShow: Orlando
FRC 1251 Alumni
FRC 1902 Mentor
Unread 05-04-2009, 16:13
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Battery PSU
I've heard good things about http://www.mini-box.com/s.nl/sc.8/category.13/.f, but I've never had an excuse to use one.
Eric Haskins KC9JVH
Unread 05-04-2009, 17:59
FRC #1178 (DURT)
Re: Battery PSU
Thanks guys. I am suprised I didn't come across these while looking for building instructions. I like how cheap they are. I was expecting $100 or more for the cheapest one.
Unread 05-04-2009, 18:35
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: Battery PSU
if you are looking for some decent processing power, you could try a gumstix processor paired with a robostix board. Those are small, relatively low power, and youd just have to voltage regulate from 12vdc to 5vdc
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 05-04-2009, 21:03
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Battery PSU
We used this power supply last year. It's designed for car computers, and as such to be able to sustain output voltage even though the input power may be dirty or prone to brown outs. We had no problems with it at all and I highly recommend it. You have to be careful about using just any power supply with the same battery connected to motors, as starting current for the motors can cause voltage drop outs.
--Ryan
FRC 766, 2015-, Mentor
[VEX] 2008 Pennsylvania: PSU Abington/Abington Bank/STEMRobotics Scrimmage results Foster VEX 1 13-12-2008 02:38
making a bench top PSU with a old school PSU John Gutmann Technical Discussion 11 19-10-2006 09:54
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
Battery archiver 2001 4 24-06-2002 01:10
battery archiver 2000 1 24-06-2002 00:26
