| My love for you never slides around. |
Aluminum Stock Supplies?
Well, I decided to try and put a gyro on our robot since we have 10-15 pounds to spare. I have everything together ready to order.....except for the stock needed to spin a 10" gyro/flywheel.
I found a website that sells a 10" diameter "rod" that is one foot long......but I only need it to be 1.5" long with the 10" diameter. Does anyone have any contacts that might be willing to provide such a piece of stock aluminum for team 3020? Doing so would earn the company name on our robot at Atlanta! We also need it turned on a lathe, either manual or CNC. I think I have a contact for getting it turned, but I am not sure they own a lathe large enough to turn a 10" diameter disk. We are located in Southern California, in Orange County. Any help is appreciated!!!!! |
Re: Aluminum Stock Supplies?
The best custom cuts I have found only have a 9" D. If you cant find any better, you could change your design to fit this... Its on onlinemetals.com
i found some aluminum round that you may be able to use. http://www.metalsdepot.com/products/...cc=%20&aident=
nevermind it costs like 1k+ for that stuff Last edited by Creator Mat : 05-04-2009 at 21:31. Reason: Ok to much $ |
Have you looked into large pulleys? You might find something in that size/weight range...
or a flywheel off a 4 cylinder engine.
Team 2168 , the CyberFalcons from Fitch High School in Groton CT had a flywheel machined from 12" stock...they purchased a 4" thick piece from McMaster-Carr...it was machined at Dominion's Millstone Nuclear Plant's machine shop. Stephanie Slezycki, who designed their gyro, is one of their engineering mentors, from Electric Boat (she's also a TechnoTick grad!).
Here's a video of it working: http://www.facebook.com/profile.php?...ros&ref=search |
#7
Buy 1.5 inch plate and turn it.
http://www.onlinemetals.com/merchant... 6&top_cat=60 or buy 3/4 inch plate and bolt it together eq, spaced for balence good luck |
#8
If you can find a sponsor with a CNC, you can buy plates like people have said and create the discs on the Mill. I think team 1388 did it and they had very good success.
#9
1.5"x12"x12" billet of 6061-T651 will run you about $75, and can be found at places like Yarde Metals Drop Zone. They have some of the best prices around for random metal parts. (Also, make sure to buy a piece that costs as least $75 (or add other random parts to order to go over $75), or you'll be whacked with an $18 service charge).
As RC said, any machine shop with a CNC mill can bolt this to a fixture plate and mill it into a disc. |
#10
Thanks for all of the suggestions! I'm going to try and get into contact with the possible CNC sponsor tomorrow, and hopefully he will know where to locally get aluminum plates as you guys have suggested.
Thanks!! |
#11
About 30 minutes drive from Rancho Santa Margarita is Industrial Metal Supply in Irvine. They have many pre-cut discs possibly in the range you're looking for, and often will have scrap for about $1.60 per pound.
#12
| Turret Supplies? | Andrew Blair | Technical Discussion | 2 | 15-01-2006 21:20 |
| Common team supplies | halomaster69 | Chit-Chat | 9 | 03-03-2005 02:54 |
| pic: 2005 Game supplies? | CD47-Bot | Extra Discussion | 5 | 02-11-2004 18:31 |
| Button supplies | archiver | 2001 | 7 | 24-06-2002 01:50 |
| Portable 12V Power Supplies? | archiver | 2000 | 2 | 24-06-2002 00:19 |
