Go to Post ...and leave your bumpers at home. - Andy Grady [more]
Unread 06-04-2009, 19:37
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Re: Digital Sidecar Ports are dropping out.
Originally Posted by Tom Line View Post
CabbageKid2,
That sounds very much like one of the standard Jaguar Failure modes. Are you running a Jaguar on that PWM, and have you tried replacing it as part of the troubleshoooting?
Hi Tom,
We don't believe it's the speed controller because once we changed the PWM port that it's plugged into it worked fine again. So once it worked, there was no need to change the speed controller.
But anything that was plugged into the bad PWM output only worked in one direction.
Digital Sidecar problem Booksy FRC Control System 6 14-06-2009 05:31
Digital Sidecar problem Jon Stratis Electrical 4 27-02-2009 09:12
Digital sidecar cable Noamr Inventor 1 22-02-2009 15:56
No RSL on Digital Sidecar shobuda999 FRC Control System 16 08-02-2009 14:28
Digital Sidecar Resistor NinJA999 Electrical 5 30-01-2009 19:53
