Go to Post Try not to fall into the trap of choosing a material because it had the most supportive comments on CD. - Ty Tremblay [more]
Go Back   Chief Delphi > Competition > District Events
Unread 07-04-2009, 00:09
Re: battery re-do match at msf
If anyone were to ask, I would recommend a shutdown under this situation. Any damage of the battery case can cause leaking, heat or explosion. Therefore any battery not contained within a robot represents a hazard. These batteries contain sulpheric acid in a glass mat. When these batteries are damaged, cases cracked and plates pushed together, they leak, ooze, smell bad and get very, very hot. anything that can be done to prevent further damage should be undertaken, immediately.
As Mike has pointed out S01 and S03 are pretty clear.
<S03> E-Stop - An Emergency Stop (E-Stop) button is located in each TEAM'S Player Station.
Pressing an E-Stop button will cause the TEAM'S ROBOT to be disabled for the remainder
of the MATCH. The E-Stop buttons are intended for remote shut down during a MATCH in
the event of safety hazards and will not otherwise affect MATCH score or duration. Any
TEAM member or referee may press the E-Stop button.
Unread 08-04-2009, 00:31
ShaunT ShaunT is offline
FRC #0217 (ThunderChickens)
Team Role: Driver
ShaunT has much to be proud ofShaunT has much to be proud ofShaunT has much to be proud ofShaunT has much to be proud ofShaunT has much to be proud ofShaunT has much to be proud ofShaunT has much to be proud ofShaunT has much to be proud ofShaunT has much to be proud of
Send a message via AIM to ShaunT
In my discussion with the head referee after the match, his plan was to call a penalty and give a yellow card for breaking the box. The FTA called the field fault for safety reasons; whatever discussion that occured did not include the head ref. After the fact it became an "oh well, let's just move on" type of scenario. This is just something that needs to be clarified at Atlanta.
It is somewhat important that this call was made twice at the Troy District event as well. However, there the battery fell completely out of the robot, so that could have been more of a percieved hazard. After the second battery ejection the robot started the match disabled as a preventative measure.
Unread 11-04-2009, 12:42
Woodie Flowers Award
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
Here is a picture from the Detroit Free Press photo gallery:
http://www.freep.com/apps/pbcs.dll/g...arams=Itemnr=7
Unread 11-04-2009, 13:24
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
This is another example of people not knowing the rules and making their own up on the fly. There should have been a robot shutdown and a penalty for exceeding the max robot size. This was questioned immediately by those watching the webcast and should have been a simple decision for a head Ref with as much experience as he has. That said, the FTA should never be involved with the match once it starts and if the decision was made by the FTA then FIRST should be training them a bit better.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 11-04-2009, 13:32
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Paul Copioli View Post
That is just not true. You can stick a screwdriver through these batteries and they will not "leak" or "spray" the acid anywhere.
Slightly off-topic, but I have to disagree here: Crush a gel cell and very nasty stuff gets splashed around.
A screwdriver causes a puncture. A 120 lb robot at 12 FPS will more likely crush, not puncture. Although unlikely, a worst case could have gelled sulphuric acid squirted over several square yards.
Don
Spring pulling before match or while in match?? Bomberofdoom Technical Discussion 3 11-01-2007 08:03
pic: Backup battery ends match inside a different robot artdutra04 Extra Discussion 19 22-10-2006 14:46
Between-Match Battery Swaps zachriggle Electrical 16 07-02-2006 23:47
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
Pre-Match/Post- Match Pit Routine Mark_lyons General Forum 14 31-03-2002 15:19
