Go to Post To me, every robot is a moving mechanical art form, a sculpture made of aluminum, motors and gears, and I think that soon we will be seeing those art forms involved in some of the most fantastic robotic "dances" that any of us have ever seen - DougHogg [more]
Unread 06-04-2009, 12:23
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Digital Sidecar Ports are dropping out.
We have been having an issue with one of our digital sidecars and the PWM outputs on it.
This sidecar was running 9 victors originally. Ports 1-9. Camera code / servo code etc had been removed for a long time, so there were no PWM assignment conflicts.
The robot ran just fine for 1.5 regionals. However, half way through the second regional, PWM port 9 stopped outputting a signal. The 5V power was still available on the power pin of the PWM, but the signal was not. Plugging it into a victor resulted in the blinking light of no-signal.
We then moved it to output 10. We checked our wiring for continuity and grounds. Suspecting the pwm cable, we tried 4 different cables with the same result. This victor was powering a single cim into a dewalt transmission that ran our shooter.
Output 10 worked fined until we arrived at the Michigan State Champs. When we powered on for a system check, we got the blinking light of no-signal on the victor again. During the trouble shooting, we swapped PWM cables and the victor. We also checked top to bottom for grounds. Finally, we moved it to PWM 3 (and disabled our cowl tilt).
This PWM ran for 1/2 of the Michigan State Champs - then the signal disappeared. We rechecked 9 and 10, and the signal on those ports had not reappeared.
Finally, we changed to our backup breakout board. We didn't have any more failures at MSC.
Has anyone else seen these issues, or is anyone versed enough on the internals of the breakout board to possible suggest a cause? I'm going to take the board apart and search for failed components once we get it back to the team room.
Unread 06-04-2009, 13:00
Re: Digital Sidecar Ports are dropping out.
9 and 10 use a separate buffer chip, it is likely that that component is your problem.
If you don't mind, I'd like to do failure analysis on this DSC. If you are attending the championship, we can swap there. Otherwise, PM me and we'll exchange shipping details. I prefer in person at ATL - talking face-to-face is so much nicer.
Unread 06-04-2009, 13:19
Mark Pendergast Mark Pendergast is offline
FRC #1760 (Robo-Titans)
Mark Pendergast will become famous soon enoughMark Pendergast will become famous soon enough
Team 1760 has had this problem as well.
I don't recall the exact details.
(We were in a hurry at the time and chose resolution over analysis.)
We lost one on the low end (1 or 2) during a practice run before we shipped.
We also lost another one (6 or 7?) when we were testing SW in our shop before we shipped.
Fortunately no problems at the regional.
Unread 06-04-2009, 13:21
In the future, please choose resolution AND analysis. We can't improve without data.
Unread 06-04-2009, 14:16
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Team 368 sort of had this problem also. Sort of beacuse the PWM still works...it just only works in driving the motor in one direction. One of our PWMs (I believe 8 or 10) only allows the motor to spin in one direction. We swapped PWM cables and it still didn't work. We know it's not programming since it worked fine for most of the Hawaii regional.
Since we were using all 10 PWMs on the digital side car, we ended up swapping the half broken PWM output with our shooter flywheel (since the flywheel only spins in one direction anyway).
Unread 06-04-2009, 14:27
Tom Line's Avatar
CabbageKid2,
That sounds very much like one of the standard Jaguar Failure modes. Are you running a Jaguar on that PWM, and have you tried replacing it as part of the troubleshoooting?
Eric, I'll PM you my info.
Unread 06-04-2009, 15:20
rspurlin's Avatar
rspurlin rspurlin is offline
AKA: Ray Spurlin
no team (no team)
rspurlin has a spectacular aura aboutrspurlin has a spectacular aura about
I don't remember any problems with PWM signals, but we did lose the GPIO on one of our sidecars. We only needed one sidecar so we were OK for our regional. I'd still like to know what happened.
Mentor(2007-2013) - Team 1379 - Gear Devils - Norcross, GA
2010 Palmetto regional Semifinalists, Judges Award
2010 Peachtree Regional Quarterfinalists, GM Industrial Design Award
2009 Palmetto Regional Finalists
2008 Bayou Regional Quarterfinalists
2008 Peachtree Regional Semifinalists
2007 Peachtree Regional Quarterfinalists
Georgia FRC Planning Committee
Unread 06-04-2009, 19:37
#0368 (Kika Mana)
Originally Posted by Tom Line View Post
CabbageKid2,
Hi Tom,
We don't believe it's the speed controller because once we changed the PWM port that it's plugged into it worked fine again. So once it worked, there was no need to change the speed controller.
But anything that was plugged into the bad PWM output only worked in one direction.
Unread 06-04-2009, 20:25
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
We too had a DSC lose PWM signal on outputs 9 and 10, and the remaining PWMs continued to function fine. We noticed that the separate small buffer chip that drives PWM outputs 9 and 10 become EXTREMELY hot during operation.
We suspect that the failure may have been caused by an ESD event when disconnecting a PWM connector from a Victor.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 06-04-2009, 21:00
DonRotolo's Avatar
Back to humble
FRC #0832
We have a DSC with PWM port 4 inoperative. Being busy we did not stop to diagnose it (other than to confirm it is dead), we purchased another, intending to return the first one to (somwehere) for repair.
Eric, I can arrange for it to be in Atlanta if you are interested.
Unread 06-04-2009, 21:07
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
we had a limit switch stop working and finally figured out that switching ports on the DSC fixed it.
2016 Central Illinois Winner. Curie Division finalist
Unread 06-04-2009, 22:09
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
We had a problem were all our DIO's stopped working. We swapped out our DSC and they worked. We then bought a new DSC to make sure we had a backup for competition and opened up the DSC that broke and found a ton of metal shavings in it. We emptied it out and it worked fine. We now use that DSC for our testing CRIO.
Unread 06-04-2009, 23:06
Don't overlook the multipin connector coming loose on the Sidecar. It may appear to be engaged but may only be touching a few contacts and show intermittent during match play while showing fine during tether in the pit.
Unread 08-04-2009, 00:38
Don -
That would be great, Thank You.
- Eric
Unread 08-04-2009, 10:57
Tom Line's Avatar
Eric - check your PM's. I sent you my contact info - where should I send the part?
Digital Sidecar problem Booksy FRC Control System 6 14-06-2009 05:31
Digital Sidecar problem Jon Stratis Electrical 4 27-02-2009 09:12
Digital sidecar cable Noamr Inventor 1 22-02-2009 15:56
No RSL on Digital Sidecar shobuda999 FRC Control System 16 08-02-2009 14:28
Digital Sidecar Resistor NinJA999 Electrical 5 30-01-2009 19:53
