Go to Post A very important thing that I learned is how to think, not what to think. - Anna B. [more]
Unread 04-08-2009, 07:48 PM
EricVanWyk EricVanWyk is online now
Re: voltage-torque curve
Originally Posted by kamocat View Post
I'm interested in how the torque of a brushed DC motor changes as its supply voltage decreases. I have seen a small amount of data that implies it is not linear, but I'm hoping for some good data on the CIM, Fisher Price, Globe, or RS-545, controlled with a Jaguar.
Currently I'm only interested in the data at the motor's max efficiency, but apparently that can be calculated from its stall torque and the RPM at no load.
My assumption is that, because it's PWM, the ratio between speed and torque will remain constant as long as the actual supply voltage remains constant. (I've heard the output of our motor controllers described as voltage, due to the lack of inexpensive oscilloscopes, and I realize this is confusing and most likely incorrect terminology. At the same time, I'd prefer not to limit my resources to teams that have both an oscilloscope and a dynomometer.)
Any links or first-hand data? Public libraries are notoriously poor at returning results for "brushed DC motor".
The simple theoretical model of a brushed DC motor states that voltage is proportional to speed and current is proportional to current.
Can you share your data? You might find that it fits once you start accounting for parasitics, such as friction inside the motor.
Teams that need an oscilloscope can use their cRIOs in a pinch. The analog input module can do half a megasample per second for a single channel, and has decent resolution.
torque curve LIL_C Technical Discussion 0 01-12-2008 02:02 PM
Acceleration Curve EricWilliams Programming 5 02-01-2006 04:27 PM
van door torque curve DLyons Motors 1 01-13-2003 09:54 PM
Drill motor torque curve thedillybar Motors 1 03-10-2002 05:19 AM
Voltage Byte -> True Voltage Ulibrium Technical Discussion 11 03-01-2002 08:55 AM
