Go to Post Gee, I wonder if AndyMark has a wedding gift registry? - KathieK [more]
Unread 09-04-2009, 08:34
Thoughts from Lead Inspectors
Ok everyone,
The division lists are out, the travel plans are almost done, the packing lists are close to finalized, the strategy teams are getting teary eyed, and the mentors are dreaming of the sleep filled nights to come in a just a week and a few days. One last thing for all you teams coming to Atlanta to work on, inspections.
What follows is a thread that lists some of the issues that we as inspectors have seen this year and will be watching for next week. I would like to ask that inspectors only post here. We can start another thread for questions if you like or you can PM with questions. So I will start...
What we will follow
The robot rules are now up to Rev K and Team Updates are up to TU19.
Bumpers.
Not enough can be said here. The GDC has spoken and we will enforce. Bumpers need to cover both sides of a corner, be at least six inches in length, be firmly attached with hardware to the robot, removable, 2 pool noodles high and covered in durable fabric, greater than 2/3 of the robot perimeter, be backed by robot structure, and have protected corners. Please refer to R08 in the robot rules and various team updates for more more info. TU#2 in particular.
Motors
The only motors allowed are those that came in the KOP or those in addition as provided in R51. These are up to 4 CIM, 2 Fisher Price (from this year only #00968-9015), 2 Banebot 545 (-12 not -120as provided with Banebot transmissions), 2 mabuchi, 2 Globemotor, 1 Keyang, 1 left window and 1 right window motor, 1 Thomas compressor.
Wiring
As required in 8.3.6 of the robot rules. Specifically #12 or #10 for 40 amp circuits. WGA must be wired to the gaming adapter power output on the PD and the robot signal light must be wired to the sidecar with the jumper in place to flash the light when enabled. Crio wired to the PD output.
Software
WPA keys will be different for the Championship and need to be installed on Thursday morning. Volunteers will be available near each inspection area to do that for you. Software needs to be LabVIEW for FRC Update 3.0a and newer, cRIO FPGA Image FRC_2009_v11. Zip and newer, WPI Robotics Library 3.0.1718 and newer, Driver Station 2009-02-010a3 and newer per R56.
Control System
Crio and camera needs to be insulated from robot frame. There must be no electrical connection made to the frame of the robot. per R41
Safety
No sharp edges please. High speed assemblies, large chain and sprockets, fans and propellors need to be shrouded to protect participants and volunteers from injury. Safety glasses in the pits, no exceptions. UL volunteers will be working closely with the inspection teams.
Pneumatics
Approved and tested parts only. Minimum system must have 1 or more storage tanks, pressure switch to allow software control of the compressor, spike to control compressor, high side gauge, 60 psi regulator and low side gauge, pressure relief valve (normally mounted on compressor), and a vent valve. Robot parts should not forcibly move when pressure is removed. See 8.3.9.
Ballast
Added weight in any form must be securely mounted to the robot frame. Wire ties may not be considered a firm mounting. Lead in any form must be sealed (painted, coated or dipped) and may not be machined in the pit. Ballast in a form that could affect or damage the field (i.e. sand, shot, BB or ball bearings) will require extra attention and discussion by the inspection team and field personnel.
As you may have experienced at regionals, finals inspections will consist of a weigh in and visual check. If you are vastly different from your check in inspection weight, full inspection will be possible. Inspections can take place at random throughout the weekend as always. Field personnel will inform inspectors to check on items throughout the weekend. If you are contemplating a change in your robot during competition, please contact an inspector before and after the change.
Thoughts from an Outsider Tstone General Forum 28 03-04-2008 00:48
Thoughts on Project Lead The Way Jeff Rodriguez General Forum 9 22-11-2007 00:22
New Bumper rule interpretation - straight from the lead inspector Gary Dillard Rules/Strategy 17 12-03-2007 14:56
Thoughts from VCU AlexM Regional Competitions 9 13-03-2002 22:04
