Go to Post I know alot of the rookie teams were helped out alot this year. Do the same thing for the rookie Volunteers as well. - wilsonmw04 [more]
Unread 09-04-2009, 09:00
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Logging console data to text file on crio
I was wondering if any of the VXWorks Guru's knew how to log all the console data to a text file. I know how to write data from within a program "c++" to a text file but, I'm looking to log "ALL" console messages. So, if a program crashes or I get any allocation errors I will be able to review that information later. Normally I would just plug a serial logger into the serial port but we aren't allowed to do that this year.
Unread 09-04-2009, 10:02
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Re: Logging console data to text file on crio
I've never tried this, but a search turned up vxWorks' iolib, containing the function ioGlobalStdSet, which should let you redirect standard output to a file that you've opened:
http://www.fys.uio.no/studier/kurs/f...ioGlobalStdSet
You likely won't get the early boot-up messages that go to console as your code won't have been loaded at that point to make this redirection, but if you are just looking to log your "printf" and other stdout-based logging output, this hopefully will do what you need. If you try it, let us know if it works.
Unread 09-04-2009, 18:49
Kingofl337's Avatar
AKA: Adam
I don't see how this will redirect the console...
Where's Joe or Greg when we need them .
Unread 09-04-2009, 18:57
Well deserved vacation, IIRC
Problem receiving console output from cRIO Arborama Programming 7 15-02-2009 03:30
Data logging to internal memory JBotAlan C/C++ 13 13-02-2009 00:04
How to use the data obtain in one C file to another C file? tommy_chai Programming 8 11-01-2008 02:17
Can the robot read a text file? CyDrive Programming 22 07-09-2007 15:43
pic: Team Data Logging Device falconmaster Extra Discussion 8 13-03-2007 10:01
